air con
air con
Postby xtreme.drifting » Sun Mar 05, 2006 6:10 pm
my air con only works on high (on low or medium nothing comes out whether its on hot or cold). has anyone else got this problem or know how to fix it? not a biggie but would be good someone knew how to fix it
Last edited by xtreme.drifting on Sun Mar 05, 2006 8:31 pm, edited 1 time in total.
xtreme.drifting
Postby rallymazda » Sun Mar 05, 2006 6:42 pm
whats your car?
good chance that its low on gas....
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby xtreme.drifting » Sun Mar 05, 2006 6:51 pm
'89 ae92 toyota levin. cost much to fix? not a diy job i'm guessing
xtreme.drifting
Postby BZG » Sun Mar 05, 2006 6:57 pm
your a/c resistor needs changing, any a/c guy should be able to sort this quickly for you, they corrode over the years.
BZG
Postby matt dunn » Sun Mar 05, 2006 7:49 pm
BZG wrote:your a/c resistor needs changing, any a/c guy should be able to sort this quickly for you, they corrode over the years.
Correct, And i'm sure he means his heater fan only goes on high, rather than the a/c itself,
Postby Alex B » Sun Mar 05, 2006 8:18 pm
Can you replace the coils with resistors? If so what sort of values would you use?
Postby sergei » Sun Mar 05, 2006 8:35 pm
If you replace coils with resistors they should be real high wattage (say if AC fan is 100W item the ressisor should be atleast half of that), and Ohms you actualy can measure with multi meter, I susspect the ressistors are of quiet low resistance...
If you are skilled with electornics best way to do it: make a driver on FET or bipolar transistor which works as pulse width modulated driver (similar to the way the injector driver works), this circuit can be very compact will not make a lot heat if designed properly (unlike the resistor design) and will be power wise much more efficient, plus you could replace normal fan adjuster with variable resisor wich will give very fine control.
BTW to find out how much power draws fan, measure the current it takes on full power and multiply by voltage of the battery at that moment.
Postby matt dunn » Sun Mar 05, 2006 8:43 pm
xtreme.drifting wrote:'89 ae92 toyota levin. cost much to fix? not a diy job i'm guessing
If you want, pull it out and send it to me and I can fix it for $25 as we stock the correct coils for them at work.
Matt
Postby xtreme.drifting » Sun Mar 05, 2006 8:57 pm
bit far away 2 send, im in auck.
xtreme.drifting
Postby FXGTV » Sun Mar 05, 2006 9:33 pm
Harden up, its not that cold/hot in NZ :lol:
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby barryogen » Tue Mar 07, 2006 7:53 am
FXGTV wrote:Harden up, its not that cold/hot in NZ :lol:
never lived in the south huh?
barryogen
2ZZ Guru in training
Postby Stealer Of Souls » Tue Mar 07, 2006 9:24 am
sergei wrote:If you replace coils with resistors they should be real high wattage (say if AC fan is 100W item the ressisor should be atleast half of that), ... how much power draws fan, measure the current it takes on full power and multiply by voltage of the battery at that moment.
Jaycar have a couple of kits capable of between 120W-240W @12V (so 144W-288W @ 14.4V). Should be easy enough to remote mount either the circuit or the adjuster pot.
'86 AE85.5 Levin
Stealer Of Souls
Postby FXGTV » Tue Mar 07, 2006 9:55 am
I sure have. Christchurch and Dunedin :)
FXGTV
Postby barryogen » Tue Mar 07, 2006 10:18 am
then you're a hard man... thats for sure.
barryogen
