BZG wrote:your a/c resistor needs changing, any a/c guy should be able to sort this quickly for you, they corrode over the years.
xtreme.drifting wrote:'89 ae92 toyota levin. cost much to fix? not a diy job i'm guessing
FXGTV wrote:Harden up, its not that cold/hot in NZ
Jaycar have a couple of kits capable of between 120W-240W @12V (so 144W-288W @ 14.4V). Should be easy enough to remote mount either the circuit or the adjuster pot.sergei wrote:If you replace coils with resistors they should be real high wattage (say if AC fan is 100W item the ressisor should be atleast half of that), ... how much power draws fan, measure the current it takes on full power and multiply by voltage of the battery at that moment.
barryogen wrote:FXGTV wrote:Harden up, its not that cold/hot in NZ
never lived in the south huh?
FXGTV wrote:barryogen wrote:FXGTV wrote:Harden up, its not that cold/hot in NZ
I sure have. Christchurch and Dunedin
