gze crank pulley removal???
Postby bluemaumau » Fri Apr 28, 2006 10:32 pm
what the title says, how do you do it?
i noticed the two holes in the pulley, are they of use?
$&#$% manuals useless.
:evil:
need to do this tonight help please.
btw engine is out of car
have removed auxilary belts and top timing cover
HELP!!!!!!!!!!!!!!
Postby bluemaumau » Fri Apr 28, 2006 10:55 pm
i cannot do the starter motor thing cuz i have no loom at the mo and no starter motor, lol
Postby IH8TEC » Fri Apr 28, 2006 11:17 pm
i had to get a pulley puller for mine in the end cause it was so tight
Postby bluemaumau » Fri Apr 28, 2006 11:19 pm
IH8TEC wrote:i had to get a pulley puller for mine in the end cause it was so tight
a pulley puller, i never seen this tool before,
is it for actually removing the bolt or, removing the pulley after the bolt is removed?
Postby IH8TEC » Fri Apr 28, 2006 11:23 pm
removing the pulley, it uses the two threaded holes on the pulley, picture rectngle bar and in the centre is a long threaded portion (pushes against where the bolt went) then connect a long bolt through the rectangle bar and into each hole on the pulley,
then turn the centre bolt and it pushes against the crack and pulls the pulley
hope thats too bad of a description
Postby bluemaumau » Fri Apr 28, 2006 11:26 pm
so it gives you something to leaver against? basically
Postby IH8TEC » Fri Apr 28, 2006 11:29 pm
yes, but you wont damage anything like the pulley edges or such, especially where the timing mark is cause thats a right biatch :roll: from using screwdriver or such.
oh and it pulls it off squarly
Postby bluemaumau » Fri Apr 28, 2006 11:31 pm
hmm sounds good, you know were to get them and how much? etc
Postby kingcorolla » Fri Apr 28, 2006 11:32 pm
wiggle wiggle, tap tap, pry pry, wiggle wiggle, tap tap tap, wiggle wiggle Tap Tap Tap
perserverance and a little impact is the key
if that fails get rough and hit it harder, or buy a puller
1983 Carina AA63 4age
kingcorolla
Postby IH8TEC » Fri Apr 28, 2006 11:32 pm
should be able to get them from repco, bnt or supercheap somewhere like that, i've just borrowed them from work in the past, so not sure on price
Postby bluemaumau » Fri Apr 28, 2006 11:37 pm
cheers ih8tec.
ive tried taping or at the end bashing.
nothing. pulley puller may be the way.
Postby slighty_sykotic » Sat Apr 29, 2006 9:43 am
$20 from super cheap.
Called "harmonic balencer puller".
Its shiney goldish colour 8)
--Sykotic
slighty_sykotic
Postby GT4 20 » Sat Apr 29, 2006 9:50 am
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby evil_si » Sat Apr 29, 2006 10:28 am
do not tap, hit or pry it off, it will render it useless. use the correct puller.
evil_si
Postby crispy'86 » Sat Apr 29, 2006 11:26 am
spray the crank with some "rost off" rust penetrant or crc, something that will enable any form of surface rust penetrantation and slide it on and off (back and forward) with the pulley puller .
Should be of some help as i've done this to all my engines
crispy'86
Postby Crucible » Sat Apr 29, 2006 8:11 pm
Yeah prying on the outside can damage the dampner like Simon suggests! Pullers locate on the inner part of the balancer so no damage is done.
Crucible
Real Life Mechanic
Postby bluemaumau » Sat Apr 29, 2006 8:38 pm
GT4 20 wrote:Image
thats for removing the pulley AFTER the bolt is removed, will investigate the harmonic thing tomorrow.
my 4age manual uses a "v" shaped tool, anyone seen, used, know were to get these???
Postby Crucible » Sat Apr 29, 2006 8:48 pm
So you havent got the bolt off?? You honestley need a Rattle gun aye, The only other option apart from that is using Large polly grips to lock the crank and stop it turning by wedging them against the ground etc and using a long breakdown bar, make sure you use 6 point not 12 point sockets so you dont strip the bolt, do that and your in a whole lot of trouble :cry:
Crucible
Real Life Mechanic
Postby bluemaumau » Sat Apr 29, 2006 9:23 pm
thats my question(should have worded it better),
HOW DO I REMOVE THE BOLT? :oops:
Postby bluemaumau » Sat Apr 29, 2006 9:27 pm
yea i need to know how to remove that bloody bolt!
