agressor wrote:my caps lock is off i was typing with shift key
agressor wrote:I HAVNT EVEN LOOKED YET HAHAHHAHA:D:D IS IT LIKE BIKE WHEELS WHERE IT SAYS LOWEST TO MAX RANGE AND SO I DO AS TEH MAX SAYS
:D:D:D
agressor wrote:
do i just use the PSI that the tire says at max of range
What is the tyre on?
What conditions is the tyre being used in i.e road driving, off road etc etc ?
What is the PSI Range markings on the trye?
You will find if you post a little more info up front others might be more inclined to reply![]()
Oh and typing without the capitals always helps too
agressor wrote:its for on road by i like to take a few country roads to speed around corners and thrash about i also like to take it off road sometimes to do rally driving
its on 15inch mags does that change how much PSI i should use
mr pad wrote:Leon wrote:250 psi at least.
At the LEAST
