ONE OF MY TIRES BE FLAT HOW DO I FIND HOW MUCH PSI THEY TAKE
Postby agressor » Tue May 09, 2006 2:08 pm
AND WOULD I PUMP UP ALL TIRES TO THAT PSI AT SAME TIME CAUSE ATM THEY ARE ALL DIFFERENT I THINK :D
agressor
Postby EVLGTZ » Tue May 09, 2006 2:12 pm
READ ON DA SIDE OF THE TYRE. IT SHOULD SAY MAX PSI TO INFLATE TO.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Silent Knight » Tue May 09, 2006 2:14 pm
Firstly, please turn off your f_ucking caps lock when posting.
Secondly, on the tire wall it should state the recommended pressure that the tyre should be pumped up to.
Silent Knight
Postby agressor » Tue May 09, 2006 2:15 pm
I HAVNT EVEN LOOKED YET HAHAHHAHA :D:D:D IS IT LIKE BIKE WHEELS WHERE IT SAYS LOWEST TO MAX RANGE AND SO I DO AS TEH MAX SAYS :D:D:D:D
agressor
I MEAN DO I USE THE MAX PSI THEY SAY IN THE RANGE
agressor
Postby Silent Knight » Tue May 09, 2006 2:17 pm
:roll:
Silent Knight
Postby HELBND » Tue May 09, 2006 2:18 pm
Its not that hard :roll:
HELBND
Postby agressor » Tue May 09, 2006 2:18 pm
my caps lock is off i was typing with shift key
do i just use the PSI that the tire says at max of range
agressor
Postby HELBND » Tue May 09, 2006 2:19 pm
agressor wrote:my caps lock is off i was typing with shift key
then youre even more of a twat than first thought :roll:
HELBND
Postby Jebus » Tue May 09, 2006 2:19 pm
agressor wrote:I HAVNT EVEN LOOKED YET HAHAHHAHA :D:D:D IS IT LIKE BIKE WHEELS WHERE IT SAYS LOWEST TO MAX RANGE AND SO I DO AS TEH MAX SAYS :D:D:D:D
YOURE A MUPPET AHAHAHAHA :D:D:D
Just put 32psi in all of them, and then fall off a roof.
Jebus
Postby 2LTR Rona » Tue May 09, 2006 2:22 pm
What is the tyre on?
What conditions is the tyre being used in i.e road driving, off road etc etc ?
What is the PSI Range markings on the trye?
You will find if you post a little more info up front others might be more inclined to reply :wink:
Oh and typing without the capitals always helps too :wink:
2002 Altezza, 1974 KE25
2LTR Rona
Postby agressor » Tue May 09, 2006 2:24 pm
its for on road by i like to take a few country roads to speed around corners and thrash about i also like to take it off road sometimes to do rally driving
its on 15inch mags does that change how much PSI i should use
agressor
Postby KwS » Tue May 09, 2006 3:00 pm
personally i think 32-36 is a good range to have tyres at, unless you want to blow them or get too much sidewall flex.
Of course, my Marina is an exception... 38psi all round :P
KwS
Postby RedMist » Tue May 09, 2006 3:02 pm
agressor wrote:its for on road by i like to take a few country roads to speed around corners and thrash about i also like to take it off road sometimes to do rally driving
You still havent supplied enough information.
You need to state what type of car it is and color. Its important to know weight distribution.
What area you race on the road in. Pressures should change dependant on road conditions.
And your licence plate number. So that if i see someone being an idiot on public roads, fitting the description of the car in my first question, in the location you described in the second, I can identify it and either ring the police or direct you off the road before you hurt someone.
Keep it on the track!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Leon » Tue May 09, 2006 3:40 pm
250 psi at least.
Postby Jazza » Tue May 09, 2006 4:41 pm
Theres at least 10 "cool" 3rd formers who sound like you at my schoo. You could start a wack gang yo.
Go home...
Jazza
Postby Ako » Tue May 09, 2006 4:46 pm
Leon wrote:250 psi at least.
Listen to leon, the rest of them are trying to lead you astray and you'll have under-inflated tyres.
Ako
Postby mr pad » Tue May 09, 2006 5:20 pm
At the LEAST
mr pad
Postby B1NZ » Tue May 09, 2006 6:04 pm
At the LEAST
shit mate, you'll roll the tyre off the rim with that amount of pressure, you need about 300psi, a little more if your numberplates on a lean
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Jebus » Tue May 09, 2006 6:29 pm
K theres funny and then there raping the corpse of a deceased thread.
This is the latter.
Jebus
