4agze wiring - Lets Play "GUESS THAT PLUG!"
Postby SpeedRacer » Tue May 16, 2006 3:18 pm
I know this is a long shot but here goes!
Converting my 4AGE bigport redtop to an ae101 4agze but turboed. my delima is that all the plugs are different (almost).
does anyone have any pics or anything to help me tell which plug goes where?
Its mostly alternator (was cut so I have to use 4age plugs), CAS, coils and ignitors. all the others i have figured.
thanks in advance
-Speed
Sinister Sleeper 35
SpeedRacer
Postby SpeedRacer » Tue May 16, 2006 3:52 pm
ok, so ive got some pics now
EDIT::scrolled down for good pics :wink: 8)
thanx
-Speed
Sinister Sleeper 35
SpeedRacer
Postby sergei » Tue May 16, 2006 4:04 pm
can you make better pictures?
#7 A/C plug
#8 Cold start water temperature switch plug
#9 WTS plug
I think 1,2,3 should go in fuse box
#12 maybe knock sensor
Postby NA Drifter » Tue May 16, 2006 4:06 pm
I'll take 8 and 9 are water temp sensors that's behide the head? ..but i could be wrong..
If you go to maybe club4ag.com and look at the spec sheet wiring for the 4agze(if they have them) there should be some picture at the back ground showing the plug.
Else use a multi meter to trace the plug back to where is plug to the ecu and see which pin are they.
Keith
NA Drifter
Postby SpeedRacer » Tue May 16, 2006 4:33 pm
cool thanx guys, any advances fo the others? i figured out 10 and 11 go to coil pack so that leaves 4, 5, 6, 12mayb, 13, 14, 15, 16
Sinister Sleeper 35
SpeedRacer
Postby IH8TEC » Tue May 16, 2006 4:37 pm
honestly if you can get better pics, could probably tell them all to you, bu some of them you can't tell sht
Postby sergei » Tue May 16, 2006 4:39 pm
If images were better I would identify all of them...
Postby SpeedRacer » Tue May 16, 2006 5:06 pm
k will go find another camera :?
Sinister Sleeper 35
SpeedRacer
Postby SpeedRacer » Tue May 16, 2006 5:52 pm
ok lets try this again
2,3,4,5 i just need to kno whr those pipes go
6 where do 6 and 7 go to/come from
8 has been cut and dont know where it came from
13 im thinking are the alternator wires but don't know about the little coloured ones
18 is the turbo pressure sensor(?) just need to know where that pipe goes (is it the same pipe as the na vac sensor?)
20 cut wire duno where it came from though :?
22 was cut also and im thinking its to the battery? same line as 3 plugs in bg and i think those are to the fuse box
tried to take them in order from gearbox side to pulley side.
thanx
-Speed
Sinister Sleeper 35
SpeedRacer
Postby SpeedRacer » Wed May 17, 2006 9:37 am
did i mention theres a chocy fish for the winner?
8)
bump
Sinister Sleeper 35
SpeedRacer
Postby Bazda » Wed May 17, 2006 11:16 am
#19 is the tps
#23 is a idle up valve thinghy
#13 is for the alternator
#14 prob 12v, ignition on, alternator excitor wire(yellow)..
Postby sergei » Wed May 17, 2006 12:27 pm
11 Injector plug (cold start?)
23 ISCV (idle speed control valve)
19 TPS
6 - 7 AC idle up lines, one before and one after throttle body (order does not matter).
18 Goes to inlet manifold, same way as NA one, thorugh a damper.
15 AC pressure switches, one pair of those need to be shorted across to stop the fan going all the time.
22 Might go to fuse box.
Have you connected speed sensor plug? #19 is very similar, also #10 is similar to reverse switch.
Postby SpeedRacer » Sun May 21, 2006 12:28 am
any advances? I rekon im just going to cut the plug off the 4ag loom and attach it to the 4agz loom. good or bad idea? any advice?
anyone in or near palmy wanna give me a hand?
have entire loom and ecu for both
Sinister Sleeper 35
SpeedRacer
