Can anyone (preferably with some engineering knowledge) tell me if there is anyway to have a blacktop flywheel safely modified to fit a FE series engine? The FE series only has 6 bolts rather then 8.
Hmmmm, when I done my silvertop conversion I had to use my flywheel from my 4afe. Two of the bolts matched up.
As my dad is a fitter and turner, we cut little bits of bolt, threaded them into the unused holes, welded them up, used a milling machine to drill and tap the new holes, and finally put the flywheel on a lathe to see if everything looked good and smooth everything out.
