Blacktop Flywheel on 4afe/7afe
Postby jeremiahnz » Sun May 28, 2006 8:32 pm
Can anyone (preferably with some engineering knowledge) tell me if there is anyway to have a blacktop flywheel safely modified to fit a FE series engine? The FE series only has 6 bolts rather then 8.
jeremiahnz
Postby sergei » Sun May 28, 2006 8:51 pm
nope, unless you are planing to change crankshafts (to make it 8 bolt)....
Postby Jebus » Sun May 28, 2006 9:01 pm
nope again, if you just want lighter could go for something like this (to the dismay of everybody anti lightening flywheels, search to find out the risks)
http://www.trademe.co.nz/Trade-Me-Motor ... 764132.htm
as 4AFE/7AFE/4AC are all the same IIRC and 1ZZFE may also be??
Jebus
Postby jeremiahnz » Sun May 28, 2006 9:22 pm
Yeah, I've seen that trademe one.
I was hoping that there may be some way to redrill a blacktop flywheel without sacrificing the integrity too much.
jeremiahnz
Postby Jebus » Sun May 28, 2006 9:30 pm
jeremiahnz wrote:I was hoping that there may be some way to redrill a blacktop flywheel without sacrificing the integrity too much.
MS Paint says No.
Jebus
Postby jeremiahnz » Mon May 29, 2006 10:30 pm
Haha, cheers for that.
jeremiahnz
Postby 20v_rollaboy » Mon May 29, 2006 11:50 pm
Hmmmm, when I done my silvertop conversion I had to use my flywheel from my 4afe. Two of the bolts matched up.
As my dad is a fitter and turner, we cut little bits of bolt, threaded them into the unused holes, welded them up, used a milling machine to drill and tap the new holes, and finally put the flywheel on a lathe to see if everything looked good and smooth everything out.
I had the flywheel on for about 20,000 kms and nothing went wrong. Only reason Ive put a proper one on was because I changed my clutch and had the oppurtunity to, and the "fe" one was a bit heavier.
20v_rollaboy
Postby Lloyd » Mon May 29, 2006 11:58 pm
While on topic, what have people used in their 7AGTEs? I'm assuming standard crank and the 7A flywheel?
Postby jeremiahnz » Thu Jun 01, 2006 6:09 am
Thanks for that. That was a similar idea to what I was thinking. Can anyone provide further opinions on whether they'd consider this to be safe?
jeremiahnz
Postby TRD Man » Thu Jun 01, 2006 10:43 am
I don't believe there's any reason why this should be a problem. Just be sure to use the right people.
TRD Man
Postby jeremiahnz » Sat Jun 03, 2006 8:06 pm
Would it be fine with the standard 4afe clutch?
jeremiahnz
Postby 20v_rollaboy » Sun Jun 04, 2006 4:17 am
The clutch will fit. Depends in what condition it is in as to how long it will last. I would change it just because you have the gearbox off and wont have to do it again down the track.
20v_rollaboy
