4age Blown Seal
4age Blown Seal
Postby ants_ae92 » Wed Aug 09, 2006 12:07 am
My ongoing problems with my 4age continue.
Blown headgasket - replaced
Blocked radiator - because of the blown radiator (flushed and cleaned)
had/have a pressurised cooling system, which we thought the flushed radiator would have fixed. I took out the thermostat to rule that out as a blockage in the system. Are there any other places that 4age cooling systems are prone to blockage. Have tried new radiator cap/thermostat.
Also, form the other day, It seems I have blown a seal around the cambelt and lost half my oil. What seals are down there? Obviously they need to be replaced. Any hints or ideas on what may have blown or gone wrong?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby Mr Revhead » Wed Aug 09, 2006 12:12 am
cam seals and crank/oil pump seal
Postby escortman » Wed Aug 09, 2006 12:15 am
o man that sucks hows the turbo conversion going
i just got a 4agze that im gona stik in the fx with the turbo on the side
4x4 toyota blizzard offroader
escortman
Postby ants_ae92 » Wed Aug 09, 2006 12:23 am
We replaced the cam seals when we did the head gasket, as I managed to get a full gasket head set for $100.
So I guess that leaves crank,oil pump seal. Thanks Revhead
Escortman,
Have my complete smallport ready for some gze pistons and rings. Going to get the gze pistons of thashz. Then its just a rebuilding process. Probably just going to take it off the road to do the conversion, at least then I can make sure its not going to crap out on me again
ants_ae92
Re: 4age Blown Seal
Postby Crucible » Wed Aug 09, 2006 1:50 pm
ants_ae92 wrote: My ongoing problems with my 4age continue.
Take it the head has been machined and crack tested?
ants_ae92 wrote: had/have a pressurised cooling system, which we thought the flushed radiator would have fixed.
If the system is still pressurising theres a good chance you still have combustion gases in the cooling system, get a tk or cyl leakage test done then go from there or you will be walking around in circles....
Crucible
Real Life Mechanic
Postby ants_ae92 » Wed Aug 09, 2006 2:25 pm
No the head had no signs of warpage at all, so we left it.
looks like I might just take it off the road, as I was going to do a turbo conversion with a small port motor/gze pistons. So I think I will just go the whole hog and do it properly with that motor. I dont want to have to spend money on a motor im just going to pull out and sit in the garage.
Thanks for your help man.
ants_ae92
Postby crnkin » Wed Aug 09, 2006 3:09 pm
Whats the crank case pressure like?
Ill put my $20 on cracked ring lands and fuccked o ring around the dip stick sheath.
deaf_homo "currrently yes"
crnkin
Postby ants_ae92 » Wed Aug 09, 2006 5:16 pm
Pressure vented to catch can, oil coming only on the front side of the engine, no oil around the rear dipstick.
ants_ae92
Postby crnkin » Wed Aug 09, 2006 5:45 pm
take a pic....
crnkin
Postby deaf_rattle » Wed Aug 09, 2006 5:47 pm
i didnt realise warping was visible, might want to get it checked :wink:
Postby ants_ae92 » Wed Aug 09, 2006 8:06 pm
Bugger, probably was it then. It definitely didnt look warped, but how mush is considered warped,? Is it like within thousands of an inch or what?
Will make sure it is done properly on the new motor then!
ants_ae92
Postby ants_ae92 » Wed Aug 09, 2006 8:08 pm
crinkin: will take a pic tomorrow.
ants_ae92
Postby Punter » Wed Aug 09, 2006 9:02 pm
ants_ae92 wrote: but how mush is considered warped,?
3/8's of F$%^ all, can't tell with your eye.
You might also want to test the hardness at the same time.
Punter
Postby Crucible » Wed Aug 09, 2006 10:19 pm
It isnt.
You can check for warp and twist with a straight edge and feelers but why guess? Get it machined and looked over properly by a reconditioner. If its been overheated the gasket has blown because the head has warped and lost tension on it, remember that the headgasket is sealing coolant and oil under pressure not to mention combustion pressure and heat. I would never put a head back on without getting it checked and skimmed, even if it came off for an oil leak and not a overheating problem. not worth it.
do it once do it right.
Crucible
Real Life Mechanic
Postby deaf_rattle » Wed Aug 09, 2006 10:23 pm
True-No-Turbo wrote:
It isnt.
yes i realise that :wink:
and yes, do it once and do it right
Postby ants_ae92 » Wed Aug 09, 2006 10:37 pm
It isnt.
yes i realise that
Point noted and lesson learned, will not make the same mistake with the turbo motor.
So most likely I still have exhaust gases leaking back into the water/cooling system. This wont cause the oil to turn misty like it does with the BHG?
ants_ae92
Postby Crucible » Wed Aug 09, 2006 11:19 pm
It isnt.
Ah i see, read it wrong sorry
Crucible
Real Life Mechanic
Postby deaf_rattle » Wed Aug 09, 2006 11:31 pm
no worries, sometimes hard to get the context right when things are written.
