Jebus wrote:Mine skids both wheels every time, as long as you break traction with no turning force (i.e straight line) If you drop the clutch while turning or when the rear axles are travelling at unequal speeds it just single spins.
ezy10s wrote:TRD still do a G series independant for early soarers- Code is RA____ csnt remember the rest but they are still available for them. these will fit into the hilux carrier
What's the actual weight of the assembly then?Drifter4ag wrote:and blah blah dont let anyone tell you its heavy .. . its only 20 kg heavier than the T series which is sweet F/a for the reliablilty
