TRD LSD v's Hilux LSD
Postby NZ_AE86 » Mon Aug 14, 2006 6:14 pm
I don't know about Auckland, I can get something made in Wellington but that doesn't help you! Anyone who does gear cutting up there? They should be able to do it. A GOOD engineer will also be able to make you some. You sorta need to know what you are asking for though or some people will be very unhelpful!
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby ezy10s » Mon Aug 14, 2006 6:18 pm
if you check out the classifieds of speedsport magazine there is usually aguy advertising this sevice- i know a couple of people who have sent their centres to him and are very pleased with his modification.
Member #244
Gone fishing until further notice
ezy10s
Postby QikStarlie » Tue Aug 15, 2006 12:09 am
Jebus wrote:Mine skids both wheels every time, as long as you break traction with no turning force (i.e straight line) If you drop the clutch while turning or when the rear axles are travelling at unequal speeds it just single spins.
yeh mine does the same, straight line it works ok.
QikStarlie
Postby Drifter4ag » Tue Aug 15, 2006 4:17 pm
and blah blah dont let anyone tell you its heavy .. . its only 20 kg heavier than the T series which is sweet F/a for the reliablilty
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby NZ_AE86 » Mon Aug 21, 2006 9:34 pm
Up until now I have never pulled a Hilux LSD to pieces, I did today and found that all they have is a preload clutch system, there is no real LSD parts inside!
What this means is that as soon as you overpower the preload torque you have an open wheeler!
So it is not as simple as just have parts made to change the ramp/loading angle. You would have to do some serious open heart missions!
The may be another Hi-lux LSD that is a different design though although after a few phone calls today I could not find this to be the case.
Current rides;
1986 Levin GT
NZ_AE86
Postby Mr Revhead » Mon Aug 21, 2006 9:39 pm
yeah hilux diffs are pretty much the same from the early 80s till the current model
and now u mention it yeah theres only the plates in there.... never really looked and thought about how they worked untill now :lol:
Postby JamesM » Tue Aug 22, 2006 1:06 pm
just get the trd lsd for independent that ezy10's suggested?
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Re: hey
Postby beeker » Tue Aug 22, 2006 7:31 pm
ezy10s wrote:TRD still do a G series independant for early soarers- Code is RA____ csnt remember the rest but they are still available for them. these will fit into the hilux carrier
Is this a definite ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby NZ_AE86 » Tue Aug 22, 2006 9:10 pm
Revheads answer to follow . . . . . . . :?:
Current rides;
1986 Levin GT
NZ_AE86
Postby Mr Revhead » Tue Aug 22, 2006 10:04 pm
ummmm 42!
i dont really know...
heres the TRD list
http://trdparts.jp/english/parts_lsd_mechanical.html
you can see what the vn001 (surf/hilux diff) fitted and what the ra010 fits.
nothing similar that i can see. but im not an expert on toyota rwd diffs
i reckon a trip to the wreckers to try a few diffs in other housings is needed.
having said that ezy10s occasionly knows what hes on about :P
trd diff codes
Postby Celica RA45 » Tue Aug 22, 2006 11:11 pm
that part no is for RA celicas with a 7.5 diff size, hilux would be G series or 8inch series i would have thought any way the ra series have been superceeded to the altezza 7.5lsd trd center hope this helps .if you give me the code of the hilux i can look into the trd diff catologe
Celica RA45
hmm
Postby ezy10s » Tue Aug 22, 2006 11:46 pm
quite interesting looking at that list- am thinking it may have been the mz210 unit as i know some of those vehicles like the gz20 and the supercharged and turbo charged 1ggte GX-81 vehicles ran the G series diff in them.
Member #244
ezy10s
Postby Mr Revhead » Wed Aug 23, 2006 9:42 am
does kinloud still have his cressida? that maybe a good vehicle to look at to see
Postby drftnmaz » Wed Aug 23, 2006 9:55 am
isnt it the mk3 supra that runs the g series diffs? i wouldnt have a clue what chassis code that is lol.
the thing with interchanging these diffs is the center can be offset slightly different to the hilux. i'm yet to get my hands on one to compare. so just thinking about the worst case sernio :?
but every diff on that page says its for a 'F' series no mention of a 'G' series diff?
also i thought a g series was 7.75" not 8" thats what the book at my mates diff workshop says.
drftnmaz
Postby mjrstar » Thu Aug 02, 2007 9:18 am
just digging up an old thread.....
does anyone have more info on fitting the supra head to the hilux housing?
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
hm
Postby ezy10s » Thu Aug 02, 2007 8:40 pm
what model supra?
you'd only use the carrier and swap it into the hilux head.
Member #244
ezy10s
hey
Postby ezy10s » Thu Aug 02, 2007 8:44 pm
Revhead- are the 41301-MZ201 units still available? seems to be according to the catalogue but could you check for me pleae dude.
these are the ones that fit into the G series head units.
Member #244
ezy10s
Postby mjrstar » Fri Aug 03, 2007 8:32 am
the main reason i'd be looking to do this is to find a taller ratio and decent lsd. i currently have a 4.3 lsd which is ok but i think the turbo would like having a bit more load, i'm also hoping to prevent the 4th gear wheelspin in the dry....
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
ah yup
Postby ezy10s » Fri Aug 03, 2007 11:26 am
ah yup- just look for a jzx81 g series diff head - i think they come with a 3.9 ratio std.
Member #244
ezy10s
Postby Stealer Of Souls » Fri Aug 03, 2007 11:30 am
Drifter4ag wrote:and blah blah dont let anyone tell you its heavy .. . its only 20 kg heavier than the T series which is sweet F/a for the reliablilty
What's the actual weight of the assembly then?
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
