BZR4AGE wrote:the ARC airbox stores air while you are in low RPM, when you start reving your car, it will already have the stored air for use, therefore helping with top end power. But don't expect too much power gain. probably just 1-2 hps, but you will be able to feel a better response from your car at top end.
RomanV wrote:with a 1600cc engine at 2000rpm, the engine is consuming approximately 1600 litres of air per minute.
barryogen wrote:RomanV wrote:with a 1600cc engine at 2000rpm, the engine is consuming approximately 1600 litres of air per minute.
eek... 27L per second, thats a fair whack of air...
so even a reletivly large one holding 6L is going to take a whole .2 seconds to empty.
