this has me puzzled
this has me puzzled
Postby IH8TEC » Thu Sep 21, 2006 3:51 pm
ok, now my motor is freshly built up, timing etc al set up properly, but i only get -8vac on my boost guage, when engine breaking it goes to -9, but wont go any further, anyone got any suggestions as to why this could be, i dont have any leaks of anything.
any suggestions, got me puzzled :?
Postby sergei » Thu Sep 21, 2006 3:54 pm
Have you plugged in the guage in the right place (not T into purge line)...
Postby IH8TEC » Thu Sep 21, 2006 3:56 pm
it's coming straight off the manifold. if you look closely you can see what i've written. i hate paint and can't edit the size of font
Postby IH8TEC » Thu Sep 21, 2006 3:58 pm
only thing i can think maybe that i've been meaning to fix for a while, is how the wastegate hose is plumbed to the bov as well, i've been meaning to make them seperate lines
but would that affect it that much?
Postby sergei » Thu Sep 21, 2006 4:06 pm
if it does not idle funny, then it is either faulty guage or blocked hose.
Postby IH8TEC » Thu Sep 21, 2006 4:08 pm
maybe it's my guage then, dont think it will be hose becuase it reads boost fine. oh and it's a autometer pro-comp guage
Postby strap-on » Thu Sep 21, 2006 4:14 pm
Can you feel it hit boost though, i know in that car you always used to be able to. So if you cant then maybe its not the gauge?
strap-on
Postby IH8TEC » Thu Sep 21, 2006 4:17 pm
yeah idles pretty good, and dan, it still feels like that :lol: just when off throttle doesn't read bugger all vaccum
Postby strap-on » Thu Sep 21, 2006 4:23 pm
oops i understand now :oops: i thought it was reading too much,
strap-on
Postby Lloyd » Thu Sep 21, 2006 7:31 pm
Swap some hoses with other ones that should have manifold vacuum also and see if the gauge reads any different
Postby IH8TEC » Thu Sep 21, 2006 7:35 pm
they are all the hoses i have onto there,
i dont have any of those vsv things hooked up, no a/c idle cause i dont have aircon. all i have is whats labelled in that pic, sorry i know it's hard to see
Postby Caveman » Fri Sep 22, 2006 12:47 am
Are you running the brake booster off the old oil breather pipe? If so not a good idea. The oil breather pipe goes before the throttle body which means off throttle theres no vacum getting to the brakes. Its supposed to run on vacum on throttle off (after the throttle body). If you have modified the old oil breather line to go into the manifold disregaurd what I said :D
Another thing I noticed, you have the petrol breather going after the throttle body :? Put it before the throttle body as it is from factory.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby IH8TEC » Fri Sep 22, 2006 2:25 am
1998 wrote:Are you running the brake booster off the old oil breather pipe? If so not a good idea. The oil breather pipe goes before the throttle body which means off throttle theres no vacum getting to the brakes. Its supposed to run on vacum on throttle off (after the throttle body). If you have modified the old oil breather line to go into the manifold disregaurd what I said :D
disregarded :lol:
umm, good point abotu the petrol breather one, wasnt' too sure which side it was meant to go on. will try that, thanks.
by the way, new turbo is on 8)
Postby dotdog » Fri Sep 22, 2006 7:52 am
Have you still got that dodgy old autometer gauge on it that the car came with?
dotdog
Postby Caveman » Fri Sep 22, 2006 8:47 am
disregarded :lol:
Oh sweet your engine bay is looking mint as 8)
You should try come to the torque performance dyno day, a few of us are going to try make it. Would be interesting to see what figure you pull.
AW11 Track Toy
Caveman
Postby IH8TEC » Fri Sep 22, 2006 10:12 am
i have to get it the car tuned first, so i'm just gona do it all at once, get edgell's to tune it on is it the velocity dyno? the new rolling road on north shore
but yeah, gotta sort the radiator out a bit more to fit better. then look at dyno time, i need about an hour on there i'd say
sounds cool though :lol:
Postby IH8TEC » Fri Sep 22, 2006 11:02 am
dylan, i owe you a beer mate, turned out to be that line going from charcoal canister, i now have -16 just from a quick start from cold.
thanks :lol:
Postby Caveman » Fri Sep 22, 2006 11:23 pm
Sweet as glad I could help out 8)
AW11 Track Toy
Caveman
Postby IH8TEC » Fri Sep 22, 2006 11:30 pm
i'll post a pic when i've fixed the radiator.
michael, yeah it's that guage, fixed the vaccum problem, and guage reads accurate now aye, i have a 6psi wastegate spring and if i turn boost controller right down it shows 6psi :)
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
