mr2--mad wrote:my car.... goes dat dat dat.
MrOizo wrote:which track you trying this on?
dont many with a big enough hill to get much past speed cut.
fivebob wrote:Here's a < $5 speed cut that works for 3S-GTE's and should work for most other Toyotas
Get a 4024 I/C from Dick Smith ( http://www.dse.co.nz/cgi-bin/dse.storef ... View/Z5624 ) then connect as follows;
Pin #1 -> Speed Input ( From Speedo ?)
Pins # 2 & #7 -> Ground
Pin #14 -> +5v
Pin #12 -> Speed output (to ECU)
Cut the speed input to the ECU and put this I/C inline and it should solve your 180km/h problems
RomanV wrote:Although since this makes your ECU think that you're going half the speed that you're actually going, powersteering settings, ABS etc may get a bit messed up?
I'm not sure if the PS and ABS run from their own circuitry though, or if the ECU controls them...
For example, PS normally 'turns off' at about 80kph IIRC, now it wont do the same till you're going 160kph. (assuming it runs from the same speed output that the ECU recieves)
RomanV wrote:And BTW, 260kph is just a tease, you'll run out of gearing and/or power to go any faster by ~245ish.
