Manifold change for ST185 GT4
Postby 4age_rage » Tue Dec 19, 2006 5:31 pm
Was just curious as to whether a 3SGE inlet manifold can be used on a 3SGTE because as far as i know the throttle body sits on the end of the manifold as opposed to the middle which would suit my frontmount setup much better. Any help would be great
HC33 Laurel
AE92 Levin
ST185 GT-4 Celica
4age_rage
Postby Adydas » Tue Dec 19, 2006 8:10 pm
Yes, as ive done the opposite by putting a 3sgte manifold onto a 3sge, just movest he inlet, but did in my case create issues with fitment of the TPS
in your case i dont know if that could cause issues under high boost say for number 1 getting less air for the mixture being the most far away inlet, Unlike the turbo setup where it goes in centrally? just a thought.
Adydas
Postby 4age_rage » Tue Dec 19, 2006 8:21 pm
I think it may just be a case of experimenting, dont plan on running too higher boost, around 1 bar, time to look for a GE manifold i suppose , wouldn't happen to have one would you?
HC33 Laurel
AE92 Levin
ST185 GT-4 Celica
4age_rage
Postby Adydas » Tue Dec 19, 2006 9:10 pm
i may actually, but its in my lockup or atm lockout as i aint paid it.
Adydas
Postby 4age_rage » Tue Dec 19, 2006 9:28 pm
Sweet as man just flick me a pm if you find it or whatever
HC33 Laurel
AE92 Levin
ST185 GT-4 Celica
4age_rage
Postby HELBND » Tue Dec 19, 2006 9:29 pm
seeing as you wont reply to PMs, where are my cupholders?
HELBND
Postby strx7 » Wed Dec 20, 2006 10:55 am
I have a caldina GT-T inlet manifold I'd sell
Postby Adydas » Wed Dec 20, 2006 11:42 am
hes after a NA style inlet manifold, not a top mount based unit as the calindas and gt4s etc use.
Adydas
Postby strx7 » Wed Dec 20, 2006 8:25 pm
caldina inlet manifold has the throttle body ideally placed if running front mount IC piping.......
Postby Adydas » Wed Dec 20, 2006 8:32 pm
u sure, i could swear it was the same..
Adydas
Postby fivebob » Wed Dec 20, 2006 9:04 pm
Adydas wrote:u sure, i could swear it was the same..
You shouldn't swear, it'll get you in trouble ;)
but it won't fit a Gen II 3S-GTE anyway
