If the LSD increases coupling in the same way regardless of whether the input torque is forwards or reverse, it is a 2 way diff. Some drifters prefer this type as the LSD behaves the same regardless of their erratic throttle input, and lets them keep the wheels spinning all the way through a corner. An inexperienced driver can easily spin the car when using a 2 way LSD if they lift the throttle suddenly, expecting the car to settle like a conventional open diff.
vvega wrote:If the LSD increases coupling in the same way regardless of whether the input torque is forwards or reverse, it is a 2 way diff. Some drifters prefer this type as the LSD behaves the same regardless of their erratic throttle input, and lets them keep the wheels spinning all the way through a corner. An inexperienced driver can easily spin the car when using a 2 way LSD if they lift the throttle suddenly, expecting the car to settle like a conventional open diff.
no_8wire wrote:possibly.... but remember you are supposed to brake/slow down before the corner anyway...
But I still dont know how to do it, and the engine is going in today so it will most likely stay in 1.5 form till I next pull it out.
