Turning TRD LSD from 1.5 - 2 way
Postby no_8wire » Wed Dec 27, 2006 7:09 pm
According to the TRD website the Mechanical LSDs can be switched from 1.5 way to 2way which is stronger?
How do you do this?
no_8wire
Postby AceSniper » Wed Dec 27, 2006 10:18 pm
as another topic said 2way was stronger setup with the TRD unit?
AceSniper
Postby no_8wire » Thu Dec 28, 2006 9:13 am
Which is why I want to do it!
But I dont know how as of yet
no_8wire
Postby vvega » Thu Dec 28, 2006 9:34 am
might no be such a great idea in a aw11
btu you can be teh ginieapig
vvega
Postby no_8wire » Thu Dec 28, 2006 9:46 am
Do you know how?
no_8wire
Postby vvega » Thu Dec 28, 2006 10:55 am
If the LSD increases coupling in the same way regardless of whether the input torque is forwards or reverse, it is a 2 way diff. Some drifters prefer this type as the LSD behaves the same regardless of their erratic throttle input, and lets them keep the wheels spinning all the way through a corner. An inexperienced driver can easily spin the car when using a 2 way LSD if they lift the throttle suddenly, expecting the car to settle like a conventional open diff.
vvega
Postby Silent Knight » Thu Dec 28, 2006 11:53 am
Wayne I suggest you never use a 2-Way LSD then.
Apparently they are not good for inexperienced drivers... wouldn't want to see you hurt yourself...
Silent Knight
Postby no_8wire » Thu Dec 28, 2006 12:05 pm
look, its going to have 3 times as much power as stock with a 3000lb pressure plate and a 3 puk...I think that will make it spin easier than a 2 way lsd...
no_8wire
Postby AceSniper » Thu Dec 28, 2006 12:09 pm
Take the crown wheel off, remove the screws under it.
you need to change how the cam ramps but I dono how you do that bit....
AceSniper
Postby AceSniper » Thu Dec 28, 2006 12:13 pm
and no a 2way will make you spin worse than that amount of power....
AceSniper
Postby no_8wire » Thu Dec 28, 2006 12:36 pm
My thoughts exactly...and I want it as strong as possible if it is to handle that power as well
no_8wire
Postby Caveman » Thu Dec 28, 2006 12:45 pm
correct me if im wrong but the only difference between the 1.5 way and 2 way lock up is on deceleration so the power increase wont really effect deceleration.
infact because you have lowered the compression i'd say it'll be less deceleration force than factory.
plus not taking vvega advice isnt a very good idea :idea:
AW11 Track Toy
Formerly known as 1998
Caveman
Postby AceSniper » Thu Dec 28, 2006 12:53 pm
he wants todo it for the lsd strength not the effects... which could be bad
AceSniper
Postby no_8wire » Thu Dec 28, 2006 12:54 pm
Well I guess I will just have to learn really really fast then eh?
:lol:
no_8wire
Postby Caveman » Thu Dec 28, 2006 1:02 pm
The problem I see here is when you throttle off your lsd is going to clamp up and lock the rear wheels. This will cause the rear wheels to want to go straight. If you are tuning while this happens uh oh
AW11 Track Toy
Caveman
Postby no_8wire » Thu Dec 28, 2006 1:06 pm
possibly.... but remember you are supposed to brake/slow down before the corner anyway...
But I still dont know how to do it, and the engine is going in today so it will most likely stay in 1.5 form till I next pull it out.
no_8wire
Postby Caveman » Thu Dec 28, 2006 1:11 pm
no_8wire wrote:possibly.... but remember you are supposed to brake/slow down before the corner anyway...
yea well shit happens when your tuning sometimes :lol: cyclist, crash, mud, etc
fwd is really cool to drive with an lsd because you point the wheels and thats the way the car will go. you can pivot the car about the front wheels which is kinda cool. Also coming in hard on the brakes is no problem as you'll always be spining both wheels the same speed and be able to turn sweet, unless you break traction...
rear wheel drive I dont have much experience but I would imagine you would have to place the arse into the position you want to be going then squirt it out of the corner. maybe ask vvega?
AW11 Track Toy
Caveman
Postby Pies » Thu Dec 28, 2006 1:14 pm
shall we start up a poll on how long before he crashes if he goes through with it?
Current Rides:
Pies
Postby no_8wire » Thu Dec 28, 2006 1:15 pm
I will crash on the way home from the tuners!
no_8wire
Postby AceSniper » Thu Dec 28, 2006 2:24 pm
you dont want it 2way.... at 100km in 5th if I give mine lil bit of throttle on the corner the car pulls straight off the road.... now think of that happening if you dont have good throttle balance and come off the gas or on the gas, there is a reason drifters like 2ways.....
AceSniper
