Small speakers
Small speakers
Postby ollieboy » Mon Jan 01, 2007 1:30 pm
I'm looking for speakers for my car but they are only about 4" and all the speakers I can find for sale are 6". Anyone know of some good 4" speakers?
ollieboy
Postby 86_rolla » Mon Jan 01, 2007 1:33 pm
i no u can get 4inch components, try hotwire i think ageeeees ago i saw some fusion 4in comps there for $199
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby DriftMonkey » Mon Jan 01, 2007 7:38 pm
Firstly, is the standard 4" speaker bolted directly to the metal, or is it part of a "baffle" made out of plastic or similar that is then bolted to the metal? If it is attached to a baffle, not the metal part of the door itself, then that baffle is probably around 6" or more in diameter (may be funny shaped though), and you can more than likely make up a MDF replacement for this with a cutout for a 6" speaker. Make sure the speaker magnet doesn't hit the window when it's wound down and make sure it fits beneath the door card too, so you might have to do some measuring to find the optimum thickness of the MDF baffle if you make one. Don't forget to paint it or whatever so it doesn't distort from moisture absorbtion too..
Either way (4" or 6"), ask on NZICE mag forums and they will give you a good lineup of great brands according to your budget, and some great tips on how to install them properly, but I recommend Focal, DLS or Rainbow (available from Paul's Audio) as some brands you've probably never heard of, but make $&#$% awesome speakers
DriftMonkey
Postby mycoolcar » Mon Jan 01, 2007 7:58 pm
86_rolla wrote:i no u can get 4inch components, try hotwire i think ageeeees ago i saw some fusion 4in comps there for $199
You say that you cannot get 4 inch components... then in the same sentence you say that you can get 4 inch components and hotwire is the place to go.
Make up your mind!
mycoolcar
Postby Mr.Phreak » Mon Jan 01, 2007 8:07 pm
mycoolcar wrote:
86_rolla wrote:I know you can get 4 inch components, try hotwire I think ageeeees ago I saw some fusion 4in comps there for $199
Make up your mind!
Read it like that
Mr.Phreak
Postby Pies » Mon Jan 01, 2007 8:36 pm
Make up your mind!
Read it like that
MR PHREAK! SAVIOUR OF THE ENGLISH LANGUAGE!!!
god if only more peopl ewere like you :P
Current Rides:
Pies
Postby 86_rolla » Mon Jan 01, 2007 8:49 pm
oh whoops my bad
Ex cars: 2E corolla
86_rolla
Postby Bling » Mon Jan 01, 2007 10:32 pm
Postby ollieboy » Tue Jan 02, 2007 3:37 pm
DriftMonkey wrote:Firstly, is the standard 4" speaker bolted directly to the metal, or is it part of a "baffle" made out of plastic or similar that is then bolted to the metal? If it is attached to a baffle, not the metal part of the door itself, then that baffle is probably around 6" or more in diameter (may be funny shaped though), and you can more than likely make up a MDF replacement for this with a cutout for a 6" speaker. Make sure the speaker magnet doesn't hit the window when it's wound down and make sure it fits beneath the door card too, so you might have to do some measuring to find the optimum thickness of the MDF baffle if you make one. Don't forget to paint it or whatever so it doesn't distort from moisture absorbtion too..
Its not in the door and its the metal mounting plate that is 4"
ollieboy
Postby DriftMonkey » Tue Jan 02, 2007 9:31 pm
Well if it ain't in the door, then it's either in the parcel tray, in which some cheapies would be fine (rear fill isn't terribly important), or it's in the dashboard, in which I recommmend some 4" components. Which components all depends on your budget. If you have $200+ to spend, I definately recommend talking to the guys at [Paul's Audio about some Rainbow, Focal or DLS components. Believe me, even the entry level models from these brands shit all over pioneer and fusion etc.
DriftMonkey
Postby ollieboy » Thu Jan 04, 2007 2:37 pm
All sorted cheers guys, bought some Rainbow SLX210's
ollieboy
Postby Snoozin » Thu Jan 04, 2007 4:07 pm
ollieboy wrote:All sorted cheers guys, bought some Rainbow SLX210's
Oh good man 8)
Snoozin
Postby Muzzie » Thu Jan 04, 2007 4:35 pm
Well if it ain't in the door, then it's either in the parcel tray, in which some cheapies would be fine (rear fill isn't terribly important), or it's in the dashboard, in which I recommmend some 4" components. Which components all depends on your budget. If you have $200+ to spend, I definately recommend talking to the guys at [Paul's Audio about some Rainbow, Focal or DLS components. Believe me, even the entry level models from these brands sh*t all over pioneer and fusion etc.
Pauls don't do Focal anymore I believe.
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby DriftMonkey » Thu Jan 04, 2007 7:37 pm
Muzzie wrote:Pauls don't do Focal anymore I believe.
Lol sorry, I bought my Focal Components off of them a while ago, but now that you mention it, I remember them having a "Focal Clearout" and that they wouldn't stock them actively anymore because of some issues with the distributor or something.
Anyway, back to the original topic, congrats on buying the Rainbow's. After you've gotten used to these things, go and have a listen to a mate's system with you shitty xplod coaxials or whatever, and you will honestly be blown away by the huge difference in sound quality :P
DriftMonkey
Postby ollieboy » Fri Jan 05, 2007 4:10 pm
I'm loving the Rainbows, farkin sound good aye. So much better than factory :lol:
ollieboy
