keyway? broken.....
keyway? broken.....
Postby bluemaumau » Sun Feb 11, 2007 9:37 pm
i think this is called a keyway? guides the crank pulley onto the shaft.
heres a pic
my question: is this broken?
shouldnt it go all the way to the end of the shaft?
Postby big_boy » Sun Feb 11, 2007 9:42 pm
no because its for a woodruff key not key steel
so should only be about 20mm ish long depending on key
for sale EE90
big_boy
Postby bluemaumau » Sun Feb 11, 2007 9:47 pm
thank god!
wasnt keen on replacing that, considering its nearly due to be going again!
Postby big_boy » Sun Feb 11, 2007 9:54 pm
just make sure you use a woodruff key not just key steel as it will be stuffed then :twisted: :twisted:
a woodruff key is D shaped :wink:
for sale EE90
big_boy
Postby bluemaumau » Sun Feb 11, 2007 9:56 pm
huh what are you talking about? :oops:
im talking about that little guide ontop of the crank shaft, it guides the pulley on?!
Postby slighty_sykotic » Sun Feb 11, 2007 10:04 pm
Just bolt it on, :P.
Looks normal.
What he means is that you can remove that sticky up bit of metal, and if you replaced it, you have to use a d shaped key, like you have now.
slighty_sykotic
Postby bluemaumau » Sun Feb 11, 2007 10:07 pm
roger, thanks
Postby matt dunn » Sun Feb 11, 2007 10:30 pm
Make sure you do the main pulley up tight and that the front pulley is not damaged around where the key goes or it can come out and let the cambelt drive slip and root your valves,
( speaking from experience )
