blacktop cams vvt pulley and tb's on a silvertop
Postby Booster » Tue Feb 20, 2007 6:50 pm
has anyone done this and is there anything to look out for when doin it.. or potential problems that can occur
Cheers Ryan
Booster
Postby 4-AGE 4-LIFE » Wed Feb 21, 2007 2:02 pm
im actually doing this now with my silvertop havn't had any problems so far, ive heard maybe just the blacktop airbox plenum sealing it shut, for the air flow meter could be a problem with not much room there
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby AceSniper » Wed Feb 21, 2007 2:07 pm
blacktop itb's would need match porting its best to just find some facelift silvertop ones,or add a blacktop head when your there, and the blacktop plenum is a *^&^ to seal for the afm but can be done. intake cam is the only one that changes if your going to pull them out just get some mild billets :D
AceSniper
Postby sergei » Wed Feb 21, 2007 2:20 pm
I use b/t plenium and trumpets on s/t thottles. I use b/t cams on s/t. cams are straight fit but I think b/t vvt pulley has locating pin in different place so timing marks will be off if used on s/t cam shaft.
Postby johntramp » Wed Feb 21, 2007 3:09 pm
is there much difference between blacktop and silvertop camshafts? is it worth while swapping them?
johntramp
Postby sergei » Wed Feb 21, 2007 3:13 pm
Slightly higher lift on inlet, and oil cut-outs on low side of the cams. Better VVT pulley.
Postby matt dunn » Wed Feb 21, 2007 10:59 pm
sergei wrote:. Better VVT pulley.
What is better about it?
They are both just on/of.
The switching mat be different but if it is it's in the ECU not the pulley.
The BT cams are timed differently from what i believe,
but as long as you use a BT pulley on a BT cam it will line up as normal.
