Intake Question
Intake Question
Postby Luke28 » Mon Apr 23, 2007 9:05 pm
Just wanted to know whether the length of your intake would have any affect on performance??
wud it make any difference having the air filter close to the throttle bodies rather then down near a headlight?? does length matter??? (of the intake that is) :lol:
Cheers - Luke
Luke28
Postby KinLoud » Mon Apr 23, 2007 9:46 pm
Yes.
Aim to have your throttle body to airfilter distance similar to the factory distance. If it's a bit longer it shouldn't hurt too much.
Make an effort to feed the airfilter cool air.
Ken
Ham
021 408 863
Postby Luke28 » Mon Apr 23, 2007 9:53 pm
Ok, thanks for that info Ken.
Luke28
Postby l1ttle_d3vil » Mon Apr 23, 2007 10:33 pm
KinLoud wrote:Aim to have your throttle body to airfilter distance similar to the factory distance. If it's a bit longer it shouldn't hurt too much.
umm...how does having the air filter closer than factory effect things? good or bad? ...and how close is too close? :lol:
e.g:
Postby Ae92typeX » Mon Apr 23, 2007 11:08 pm
Cant say Ive read much for injected engines on it, but on carbs many wrters - vzard etc- used tuned length intakes. The longer 'generally' assisting the torque curve.
Ae92typeX
Postby ROBODISCO_20v » Mon Apr 23, 2007 11:12 pm
l1ttle_d3vil wrote:Image
Thats way too close. You'll loose power/throttle response
ROBODISCO_20v
Postby frost » Tue Apr 24, 2007 1:26 am
I've seen lots of ae86 drifter cars in japan have that set up (above pic) i even have pics of just a bell mouth in front the butter fly, don't know why the hell they do it but its very popular over there, it must kill low down torque but i guess they don't really need low down when there sitting at red line sideways. if i had a scanner i can post up some pics from my ae86 REV tuning mag.
i really don't see the difference between running that set up and having open quads.
Postby l1ttle_d3vil » Tue Apr 24, 2007 2:29 pm
ROBODISCO_20v wrote:Thats way too close. You'll loose power/throttle response
heh, thats how ive had mine setup for the last 18 months :lol:
anyone know roughly what the standard distance should be from the TB? guess I should look at changing it! :roll:
Postby deaf_rattle » Tue Apr 24, 2007 2:49 pm
i know of a n/a rotary engine that has carbon fibre intake trumpets that change length depending on rpm. pretty awesome work
Postby Caveman » Tue Apr 24, 2007 2:56 pm
e.g:
Mine runs like that too!
Didnt have the induction pipe so I was like meh, just chuck the filter on :lol:
Is it the same with individual throttles? I always see them with open trumpets
AW11 Track Toy
Formerly known as 1998
Caveman
Postby bluemaumau » Tue Apr 24, 2007 2:57 pm
i was under the impression that the length of the filter trumpet only effected cars running ITBs
Postby KinLoud » Tue Apr 24, 2007 3:08 pm
This is an article about intake lengths from the filter to the throttle body.
http://www.cannonballforums.se/viewtopi ... 659bccf14c
Can't seem to find the original but the important bits are in english.
Ken
Ham
021 408 863
Postby Luke28 » Tue Apr 24, 2007 8:29 pm
Interesting!!
Luke28
Postby thaphatty » Wed Apr 25, 2007 12:53 am
redmist sig.
thaphatty
Postby Adamal » Wed Apr 25, 2007 1:08 am
thaphatty wrote:redmist sig.
The answer is, and always has been, HELMHOLTZ!!!!!
Postby mr30%jr » Wed Apr 25, 2007 10:40 am
if youve actually seent the blue top intake its really not that long standard the filter is only 20cm away from the TB and theres only a 30 cm "trumpet" off that with no intake resonators like 90s intakes
mr30%jr
Postby bluemaumau » Fri Jun 15, 2007 11:06 am
so will having your intake in under the guard make a difference?
compared to a Cold air box in the bay?
just seems easier to run a pipe through the inner guard :lol:
