20 Valves really that bad?
Postby oem-r » Fri Jun 01, 2007 1:43 pm
b16a>20valve :lol:
oem-r performance
oem-r
Postby Lith » Fri Jun 01, 2007 2:04 pm
Mr Revhead wrote:that the curves were a lot fatter from 3500-4000.
ie not a 45 deg angle like that one. and peak torque was around 4500. with everything tailing off around 6400ish, rather than peaking
Ah ok, the fatter thing can be caused by how the Dynapack software scales into the torque curve. This one if you calculate it down actually makes a minimum of 130nm @ hubs and peaks at 156 - so a range of 26nm over a 6000rpm rev range. The reason it looks peaky/steeper is where the 20v stays (and feels to drive) flat, the VTEC starts off as a semi-traditional 1.6 NA thing - then raises or at least maintains its VE as the revs rise. Rising torque with rising revs gives a steep torque curve.
For what its worth, Loudtoy's AE101 peaked at 140nm @ hubs.
Lith
Postby bOi » Fri Jun 01, 2007 3:02 pm
subie racer wrote:b16a>20valve :lol:
we going in circles again... :lol:
bOi
Postby d1 mule » Fri Jun 01, 2007 3:24 pm
if the 20v is mounted north-south it is a far superior engine to the b16a none of this FWD crap. however since they are both FWD from factory id rather a B16A over a silvertop but not a blacktop.
d1 mule
Postby Defective » Fri Jun 01, 2007 3:29 pm
d1 mule wrote:if the 20v is mounted north-south it is a far superior engine to the b16a none of this FWD crap. however since they are both FWD from factory id rather a B16A over a silvertop but not a blacktop.
what if theyre both mounted north-south....... :P
Defective
Postby sergei » Fri Jun 01, 2007 3:38 pm
Well - honda will drive backwards ;).
Postby Lith » Fri Jun 01, 2007 3:46 pm
Like Tow Mater!!! W00t!
Lith
Postby pc » Fri Jun 01, 2007 3:55 pm
Some actual 4age numbers in this thread.
http://forums.toyspeed.org.nz/viewtopic.php?t=30705&highlight=dyno
some b16s on the same dyno got 110KW, 113KW & 119KW
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby AceSniper » Fri Jun 01, 2007 5:35 pm
:roll:
Guess I should dyno hmmm
AceSniper
Postby frost » Fri Jun 01, 2007 5:46 pm
so true, thats when you really see the blacktops at there best, you can get more traction for taking off at higher revs where the sweet spot is not so far away, and you wont be wheel spinning, in the fwd they are more docile,b16's don't really float my boat. rev all day but dont get anywhere.
id like to see how a blacktop in a aw11 is like. if any one has this setup lets swap cars for a few days. lotus sus+ blacktop :twisted:
Postby the fallen303 » Fri Jun 01, 2007 6:38 pm
AceSniper wrote::roll:
yes, yes you should...
there's one tomorrow isn't there? :lol:
true house of JZ
Stay true to the origin
the fallen303
Postby Dragger_Dan » Sat Jun 02, 2007 12:34 am
Keep the $&#$% rotaries out of this :lol:
Dragger_Dan
Postby Bazda » Sat Jun 02, 2007 2:41 pm
20v turbo ftw
Postby flygt4 » Sat Jun 02, 2007 3:39 pm
Bazda wrote:20v turbo ftw
i concur
flygt4
Postby IH8TEC » Sat Jun 02, 2007 3:49 pm
flygt4 wrote: i concur
you need to beat me first :P
Postby slighty_sykotic » Sat Jun 02, 2007 4:00 pm
frost wrote:id like to see how a blacktop in a aw11 is like. if any one has this setup lets swap cars for a few days. lotus sus+ blacktop :twisted:
Fcking awesome I must say :D
Pity I sold it :(
slighty_sykotic
Postby Cakky » Sat Jun 02, 2007 5:16 pm
ive never had a b16 keep up with me with my 20v
Cakky
Postby 20v_rollaboy » Sat Jun 02, 2007 5:35 pm
Well, heres my dyno plot, if it helps to this thread at all.
Completely standard silver-top, with screwed vvt pulley I believe.
20v_rollaboy
Postby Dirtbag » Sat Jun 02, 2007 6:49 pm
screwed vvt pulley = clicky clicky right? yea pretty sure my vvt pulley is bung, I drove a mates ae101 and whilst it didnt pull that much harder it did feel a lot smoother with the power delivery compared to my vvt impaired silvertop.
My personal opinion on 20vs is alot like opinion on hondas, good...sometimes, but sometimes ruined by the users of them, eg the atards who think theyve got the fastest car in the world cos they have vtec/20v, and the usual chromie crowd for hondas.
Even with the screwed vvt pulley and 195ks on the engine, the engine still can provide a helluva lota fun.
After driving quite a few cars I would say that 20v deff rates up there for fun factor, keeping the revs up is all part of the fun :D Teaching yourself to heel-toe is a good way to keep the revs up, also helps me with my crunchy 3rd gear synchro
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby MacrosSiR » Sat Jun 02, 2007 7:53 pm
Cakky wrote:ive never had a b16 keep up with me with my 20v
you should have come up to meremere a few years ago for the HvT drags then.
MacrosSiR
