Mr Revhead wrote:that the curves were a lot fatter from 3500-4000.
ie not a 45 deg angle like that one. and peak torque was around 4500. with everything tailing off around 6400ish, rather than peaking
d1 mule wrote:if the 20v is mounted north-south it is a far superior engine to the b16a none of this FWD crap. however since they are both FWD from factory id rather a B16A over a silvertop but not a blacktop.
Defective wrote:d1 mule wrote:if the 20v is mounted north-south it is a far superior engine to the b16a none of this FWD crap. however since they are both FWD from factory id rather a B16A over a silvertop but not a blacktop.
what if theyre both mounted north-south.......
AceSniper wrote::roll:
Guess I should dyno hmmm
frost wrote:id like to see how a blacktop in a aw11 is like. if any one has this setup lets swap cars for a few days. lotus sus+ blacktop
