TRD LSD v's Hilux LSD
Re: hey
Postby Mr Revhead » Fri Aug 03, 2007 11:30 am
ezy10s wrote:Revhead- are the 41301-MZ201 units still available? seems to be according to the catalogue but could you check for me pleae dude.
these are the ones that fit into the G series head units.
one in stock at TNZ even
holy crap
Postby ezy10s » Fri Aug 03, 2007 11:34 am
Sweet roll up people- trd G series LSD in stock!!!!
Ditch that doogy old toyota LSD and slap this 2way in- single spinners are a thing of the past! roll up roll up!!
:lol: :lol:
damnit i wonder if you can put a cressida G series centre in a TA63 sub frame.....
Member #244
Gone fishing until further notice
ezy10s
Postby gepsk8 » Fri Aug 03, 2007 7:42 pm
Price? has any1 done it?
gepsk8
not i
Postby ezy10s » Fri Aug 03, 2007 8:04 pm
you be the first- bloody legend
Member #244
ezy10s
Postby QikStarlie » Fri Aug 03, 2007 10:39 pm
putting a supra g series lsd, in a hilux head at the moment. machining required. but should fit other than that
QikStarlie
Postby gepsk8 » Sat Aug 04, 2007 2:27 am
nice, let us know how u get on.
gepsk8
hmm
Postby ezy10s » Sat Aug 04, 2007 10:56 am
QikStarlie wrote:putting a supra g series lsd, in a hilux head at the moment. machining required. but should fit other than that
What machining you having to do?
Member #244
ezy10s
Postby QikStarlie » Sat Aug 04, 2007 11:57 am
bearings are bigger on the supra one, and the part the bearing sits on. so wont fit stright in the hilux carier. could probably go to a helpfull bearing shop and find something to match. but im just going to spin the ends down and use the hilux bearings. since lathe is at hand
QikStarlie
ah yup
Postby ezy10s » Sat Aug 04, 2007 2:48 pm
if you look at the trd lsd catalogue they say you need to run their special side bearings- this is a common thing and i had to sort this out with my F series TRD lsd when i bought it also.
The bearings are available form
Auckland Bearings LTD here on the shore(im sure most bearing shops also carry these). From memory i think trade cost set me back approx $50 for the pair.
Member #244
ezy10s
Postby QikStarlie » Sat Aug 04, 2007 8:28 pm
QikStarlie
Re: hey
Postby QikStarlie » Sun Aug 05, 2007 4:46 pm
how much would one of them set ya back?
supra one = same issue as hilux. unless its all the masses of na power it cant handle..
QikStarlie
Re: hey
Postby matt dunn » Sun Aug 05, 2007 9:46 pm
So you are saying the supra one is no good either?
Im thought the issue with the hilux one was it has no ramps at all,
so cannot even be improved much.
Does the supra one have ramps? Maybe the one you tested is just a weak one and may need a "tune up" so to speak
Postby Mr Revhead » Sun Aug 05, 2007 9:54 pm
arnt the supra ones torsen?
Postby QikStarlie » Sun Aug 05, 2007 11:12 pm
this one is clutch type. seems to be the same deal as the hilux one. i did spilt it in half, but really didnt take much notice other than a quick look at a couple of the plates for excessive wear then bolted it back together. wish i had of striped it right down, and had a better look now.
does just the same as what the hilux one does. works fine in a straight line, but when , how should i say it.. doing a "u-turn" it just spins the inside wheel.
has pretention but feels as tho it has no ramps like the hilux one. the case looks the same as the hilux one also.
QikStarlie
Postby mjrstar » Tue Aug 07, 2007 8:43 am
The trd one will set you back about 1600 plus GST.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby QikStarlie » Tue Aug 07, 2007 7:02 pm
has anyone used a modified hilux one from this dude? :
http://www.raeemersonmotorsportdevelopm ... parts.html
http://www.raeemersonmotorsportdevelopm ... luxlsd.jpg
1600+ for trd one sounds a bit harsh, retail?
QikStarlie
yep
Postby ezy10s » Tue Aug 07, 2007 7:09 pm
Damian ran one of these in his ae86 while he owned it and Grant Hohaia runs one in his super GT ae86. reckon its money well spent
Member #244
ezy10s
Postby QikStarlie » Tue Aug 07, 2007 7:13 pm
ah sweet, damian told me about it ages ago. but wasnt sure if that was the place he got it from or not
QikStarlie
Postby spencer » Tue Aug 07, 2007 8:56 pm
surely the supra one just needs a rebuild pretty sure there 4 pinion over the hilux 2, and was sure they had the lock up ramps when we pulled apart a chaser one (same thing)
ms63 crown
spencer
Postby QikStarlie » Tue Aug 07, 2007 11:47 pm
yeh i dunno aye. just pulled the hilux one apart. looks just the same as what the supra one did. i'd have to take the other one apart again to be sure tho.
meh.
QikStarlie
