***link g3 groupbuy***
Postby bluemaumau » Fri Oct 19, 2007 9:36 am
how are you controlling boost? external or ebc?
Postby IH8TEC » Fri Oct 19, 2007 9:44 am
gasman wrote:can we push the closing date any earlier? i want to get mine a bit sooner than dec. cant we use stock air intake temp sensor with the link?
they have a specific sensor for turbo cars, as it reacts quicker with temp rises, becasue of the boost.
i've used pretty much most of my factory sensors though just with the addition of that one.
Postby bluemaumau » Fri Oct 19, 2007 9:57 am
if your running a EBC you will need a boost control solinoid from what i gather, can anyone confrim?
Postby IH8TEC » Fri Oct 19, 2007 12:53 pm
bluemaumau wrote:if your running a EBC you will need a boost control solinoid from what i gather, can anyone confrim?
you ONLY need the boost control solenoid IF the link is controlling your boost
an EBC has it's own solenoid
Postby ~SlideWays~ » Fri Oct 19, 2007 12:59 pm
Unless the Link G3's have improved the boost control hugely over the previous model LinkPlus I wouldn't bother using it for boost control.
My LinkPlus G1 which is the last model before the G3 was released is arse at controlling boost. Its just plain arse. :lol:
~SlideWays~
Postby escortman » Fri Oct 19, 2007 6:21 pm
na mines just internal atm but wil prbly scoer my m8s ibc
4x4 toyota blizzard offroader
escortman
Postby gasman » Fri Oct 19, 2007 8:59 pm
how hard was it to get the link controlling the boost correctly?
would be quite handy because then you cold do boost per gear or low boost when cold unless that a feature only found on the linkplus
"What can possibly go wrong?"
gasman
Postby ~SlideWays~ » Fri Oct 19, 2007 9:32 pm
gasman wrote:how hard was it to get the link controlling the boost correctly?
Pretty hard..considering it never has been able to hold a constant psi. This was done my Andre Simon and he tried a couple of times. Its ok normally but when its cold weather and/or I'm pushing it at the track, it just keeps hitting boost cut...which aint fun :roll:
He did say from the get go that Link's are'nt any good at boost control.
But as I said, this is a "G1". The G3 may be a different story.
~SlideWays~
Postby matt dunn » Fri Oct 19, 2007 9:45 pm
Yeah, anything that is not a G3 and it not even worth trying to run the boost contol.
I spent hours at the track with my G1 linkplus trying to get it too work.
They were closed loop and not that flash.
The new G3 is open loop only so far, and will work really well as long as the car has a wastegate that works properly.
and you can run a dash mounted boost knob, or gear dependant or whatever you want.
Postby Dell'Orto » Sat Oct 20, 2007 1:01 am
~SlideWays~ wrote:Pretty hard..considering it never has been able to hold a constant psi. This was done my Andre Simon and he tried a couple of times. Its ok normally but when its cold weather and/or I'm pushing it at the track, it just keeps hitting boost cut...which aint fun :roll:
I also had another tuner tell me a few years back that the Link boost control was pretty poor, this was with a V4 LinkPlus.
Postby bluemaumau » Sun Oct 21, 2007 6:57 pm
5 bar map sensor
LEM G3 $135
LinkPlus $50
Postby 4agtepwr » Fri Oct 26, 2007 4:03 am
The new link boost control is as good as any good aftermarket ebc, they will hold a pretty much perfect boost curve as long as you have a decent wastegate setup and you can have a pot wired that lets you run vairable boost levels:) So stoked with the one in my mr2, drives like a car with a factory ecu.
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby YeMs » Fri Oct 26, 2007 12:14 pm
if any 1 wants them for that price, i can get them for pretty much that price. i got an LEM G3 for $1350 the other day. takes 1-2weeks to be delivered to me.
Your local Hybrid Elite tech
YeMs
Postby YeMs » Fri Oct 26, 2007 12:15 pm
also my brother is an auto electrician and for toyspeed members he will give you a sweet deal to wire 1 of those badboys up.. specially if you buy off us ;)
YeMs
Postby Bling » Fri Oct 26, 2007 12:22 pm
did yours come with boost control solenoid or a air temp sensor for that price?
QUOTE:
So the deal is: a FREE boost control solenoid ($150) OR an inlet air temp sensor ($120) AND free shipping with every ECU purchased.
Postby YeMs » Fri Oct 26, 2007 12:54 pm
im just sayin i can get them for that price daily as there are a few people asking for them sooner/later, i havnt priced the other sensors as yet.
YeMs
Postby Bling » Fri Oct 26, 2007 3:17 pm
yeah i'm just asking if your price you can get daily... comes with a sensor or not.
1350 might be the daily price, but I imagine that getting it through the group buy, you get a free sensor as stated.
if yours comes with the sensor for the same price, then thats sweet
Postby barryogen » Fri Oct 26, 2007 4:15 pm
matt dunn wrote:The new G3 is open loop only so far, and will work really well as long as the car has a wastegate that works properly.
Gear dependant aye... handy indeed... will have to skip this group buy, but keen on one in about 6 months.
barryogen
2ZZ Guru in training
Postby bluemaumau » Sat Oct 27, 2007 11:48 am
alright time for some committment people
bluemaumau - LEMg3 + 5 bar map sensor + free shipping and inlet temp sensor.
Postby try_hard » Sat Oct 27, 2007 3:40 pm
im looking at getting the linkplus G3 + 5 bar map sensor.. but at the when is all of this going ahead?
AE92 Trueno Sprinter 4AGZE
try_hard
