suspention certing
suspention certing
Postby 79rolla » Mon Nov 12, 2007 9:28 pm
hey bout to do engin transplant in my ke30 and trying to get as much as i can that needs certing done at same time
im just wanting to know what suspention changes should be certed???
struts im guesing?
leaf spring adjustments?
wont need hight aslong as i dont lower it much??
just cheaking on what i can save for later
thnx
past: AE82 FXGT
79rolla
Postby Bling » Mon Nov 12, 2007 9:50 pm
define "struts" are they from another car or what?
define "leaf spring adjustments" what have you done.
"wont need hight aslong as i dont lower it much"
As long as chassis isn't lower than 100mm off ground no.
the more detailed info you provide, the more detailed answers you will get you will find.
Postby 79rolla » Mon Nov 12, 2007 10:12 pm
well im gonna prbly add another leaf and reset the rear springs but havint disided exactly what to do with the frount trying to diside what i can get away with and witch is most worth wile ect
also of i cange calopers and break diskes in the frount and probly drums at bank will they need certing?
past: AE82 FXGT
79rolla
Postby Bling » Mon Nov 12, 2007 10:52 pm
I think its a case of non-factory parts need certing with the likes of brakes.
suspension (rear leafs) i'm sure you'd be fine without cert
Postby Lloyd » Tue Nov 13, 2007 7:31 am
If you change the suspension then it'll get listed on the cert plate and you'll most likely get the height written on plus or minus 5%, so if you're going to change it later on (height) then you might find it a hassle getting warrants
Postby l1ttle_d3vil » Tue Nov 13, 2007 8:10 am
HRT wrote:If you change the suspension then it'll get listed on the cert plate and you'll most likely get the height written on plus or minus 5%, so if you're going to change it later on (height) then you might find it a hassle getting warrants
thats true, but legally if the car is over 100mm and all the suspension is legit (ie, captive springs etc) you don't need a cert for it anyway.
if suspension / struts is a direct bolt in replacement, you don't need a cert.
it CAN be altered afterwards, but you may find it a hassle if you have a picky wof inspector. I got my car certed, bolted in completely different struts and lowered it another couple of inches so it sat at about 115mm and still got WOFs.
Postby Grrrrrrr! » Tue Nov 13, 2007 9:55 am
If in doubt read the rules
http://www.lvvta.org.nz/CertThresholdSc ... il04V3.pdf
How do you "reset" leaf springs?
If it involves heating them then its a no-no.
Grrrrrrr!
Postby Bling » Tue Nov 13, 2007 12:19 pm
much the same as heating springs and compressing them, i'm sure the right company will do the right job and it will be sweet
Postby touge rolla » Tue Nov 13, 2007 3:03 pm
though not suspension, as you are changing the engine you will need a drive-shaft hoop (or hoops for two piece) for cert.
touge rolla
Postby HamzGTT » Tue Nov 13, 2007 10:31 pm
When modifying a vehicle from factory with after market parts (except OEM or direct aftermarket replacments) you will need a cert I.E adjustable struts, camber kits, bigger discs/calipers setups. If you lower a vehicle 100mm below a structral (that means sway bars, X members, floor stiffners) part of the car a cert is reqd. even if you fit wheel spacers for your mags a cert is reqd.
REFR VIRM (Vehicle Inservice Requirements Manual) on LTNZ web site.
HamzGTT
Postby HamzGTT » Tue Nov 13, 2007 10:38 pm
BZG|Bling wrote:much the same as heating springs and compressing them, i'm sure the right company will do the right job and it will be sweet
Technically this is Illigal any modifaction to a factory spring is not allowed but some how thay manage to get away with it. I see it all the time.
HamzGTT
