ke70 owners!, steering upgrade, advice needed
Postby Mike- » Mon Jan 21, 2008 4:53 pm
ok at the moment ive got a wagon with circulating ball steering,(i think)
and im wanting to get rack and pinion,
ive got a wreck with the rack and pinion in it and want to know if its just a
case of replacing the steering rack or the whole front suspension/steering setup, and is there any fabrication involved.
thanks
Mike-
Postby Mr Revhead » Mon Jan 21, 2008 5:04 pm
know anyone close by whos got a r&p one you can look at?
tbh iv never even looked at the steering or a box type...
Postby fangsport » Mon Jan 21, 2008 5:22 pm
you will more than likely need to cut the section of firewall where the steering shaft comes through and swap it for the donor.
box steering comes out straight, whereas the rack steering comes through on quite an angle
fangsport
Postby Dell'Orto » Mon Jan 21, 2008 5:57 pm
The rack bolts to the crossmember, I'd imagine the steering box versions wont have the mounts/bolt holes on it to take a rack.
Postby Mr Revhead » Mon Jan 21, 2008 6:10 pm
fangsport wrote:you will more than likely need to cut the section of firewall where the steering shaft comes through and swap it for the donor.
yeah steering box will mount to the chassis, but i dont think you need to mod the firewall?
a r&p steering column including the mount should put it in the right place, you may need to drill holes for the mount, and you may need the plastic cowls as well (but im not sure on that bit) you may also need the r&p brake pedal as the coloum runs in a slightly different angle as fangsport mentioned
you will need a r7P cross member. i dont know if the steering arms are the same or not.... i have some KE70 steering arms if you need some.
while it wil take a little bit of work, i dont thinks its a drasticly hard job... but very worth imo
Postby scott900 » Mon Jan 21, 2008 6:36 pm
if you've got the whole wreck, then i'd say swap cross member, steering column and everything over.
cant you look at them both to compare?
i've thought of doing the same thing.
steering arms might be different, but i don't know...
scott900
Postby Mr Revhead » Mon Jan 21, 2008 6:48 pm
oh i missed the bit that said you had a wreck there!
get under them both and start comparing!
Postby fangsport » Mon Jan 21, 2008 7:00 pm
compare the cut-out on the firewall.
completely different
fangsport
Postby Mr Revhead » Mon Jan 21, 2008 9:22 pm
interesting... that wasnt pointed out to me
Users browsing this forum: Bing [Bot] and 4 guests
