Bazda wrote:haha
its a bit different when ur backing off to do a 10
braking, even
audi man wrote:Back from the nats, was a good day but not for the supra first run no traction of the line as the track was still damp and we had a bad miss as i was eating spark plugs but we did a 10.7 @ 190KMS, on my 3rd run i smashed my diff doing a burn out, but i do know there is a 9sec pass in her but its getting it right.
audi man wrote:As any one tryed a trd diff, and would you think thay would be stronger than a torsan.
Blake we have a trd diff on its way, i can only try it i do now the next thing to go will be the crown wheel and pinion and we are looking into that now.BlakeNZ wrote:I have a trd 2 way diff, after cracking the torsen carrier housing. my viscious shift kitted auto was most likely the culprit. a lot of the big power supras in japan go to a TRD lsd,so i can assume they are stronger. however, it doesn't stop you breaking the pinion/crown wheel combo.(which i heard that the croydon supra did a couple of times.)
lol tryed a clutch lsd once, i got about half way down the strip befor all the clutches were soup.AceSniper wrote:torsen.... why dont you goto a plate lsd?
