cat007 wrote:You don't need a turbo timer! HAHA - that really is quite funny.
Ever seen what happens to the bearings on a turbo that has been just "turned off" after driving, year after year?
Ever seen what happens to oil at 400+ degree's?
not pretty.....
not_paul_from_waiheke wrote:isnt the other purpose of a turbo timer to let the turbo spool down before the oil supply is cut off and the bearings arent left spinning with no oil?
flygt4 wrote:yeh if you look on youtube for a f40 dyno run, their wastegates are farkin loud![]()
audi quattros also ran factory external wastegates though, and they have their small flexi and merge into the exhaust pretty close to the engine.
YeMs wrote:cat007.. i supose you are 1 of those people that starts their car up and leaves it idling for 5 minutes in the morning to 'warm it up'... and you say its your labour of love but in an actual fact your doing more damage than good with turbo timers.
flygt4 wrote:not_paul_from_waiheke wrote:isnt the other purpose of a turbo timer to let the turbo spool down before the oil supply is cut off and the bearings arent left spinning with no oil?
can't see how that would work.
when the turbotimer turns off the turbo has to spool down anyway. so whether you turn it off from idle as soon as you stop, or 2 minutes later its exactly the same.
cat007 wrote:Exactly - the idea of a turbo timer is not to spool the turbo down, but to allow the core and shaft of the turbo to become cool enough so that when the flowing oil in and around these items stops flowing, it doesn't cook itself and get burnt.
fivebob wrote:Please explain how idling the engine has any significant effect on a water cooled turbo??? Or indeed why a water cooled turbo needs cooling down any further than it already is?
I'll give you a hint, water boils well before oil cokes
fivebob wrote:Every modern Toyota one is, and here's me thinking this was a Toyota forum
cat007 wrote:fivebob wrote:Every modern Toyota one is, and here's me thinking this was a Toyota forum
"Anyone who has a modified car, put their hands up"
hmmm - talk about a mexican wave.....
