KinLoud wrote:Gas turbine engines are not as efficient as piston engines.
Their advantage is power to weight/size ratio.
However it doesn't mean you can't put one in a car.
A few car companies produced prototypes in the 60's
Also somewhere on youtube I found a racecar that has a turbine engine that powers the turbo for the piston engine! No Lag!!!
Ken
Auck
021 408 863
KinLoud wrote:Also somewhere on youtube I found a racecar that has a turbine engine that powers the turbo for the piston engine! No Lag!!!
Ken
Auck
021 408 863
Trls250s wrote:Id hate to service that engine.
Awsome the first thing they bolt it to is a trike haha.
KinLoud wrote:A few car companies produced prototypes in the 60's
Ken
Auck
021 408 863
Guss wrote:KinLoud wrote:Gas turbine engines are not as efficient as piston engines.
Ken
Auck
021 408 863
not true GT's can get up around 50% efficiency though in a very narrow power range.
nick mann
http://www.youtube.com/watch?v=4KafnRQVgeg
Guss wrote:one problem with gt powering a generator and then motor is all the extra weight of generator and motor AND some batteries.
Starting gt's uses vast amounts of fuel so you need enough storage so you don't need to start stop the gt often.
Also 'small' gt's at around 30Kw are only ~30% efficient, get to an efficient size and your generator and batteries will be massive.
you'll probably be interested in the engine & fuel forum here http://www.eng-tips.com/
Users browsing this forum: No registered users and 39 guests
