I'm needing to put a new diff in the starlet,
Wanting something that is about 60mm wider than a standard Starlet diff, A mate runs a EX Lancer diff in his which is about 60mm wider.
Problem is sourcing one of those diffs. Anyone else got any ideas of what I could use? On a budget and not worried about LSD as long as it's 4x114.3 or 5x114.3
Also looking to widen the front track by about the same 40mm, want to know what the best front suspension setup would be and not to expensive
