Starlet KP61 Track width
Postby philk » Sun Oct 19, 2008 6:59 pm
I'm needing to put a new diff in the starlet,
Wanting something that is about 60mm wider than a standard Starlet diff, A mate runs a EX Lancer diff in his which is about 60mm wider.
Problem is sourcing one of those diffs. Anyone else got any ideas of what I could use? On a budget and not worried about LSD as long as it's 4x114.3 or 5x114.3
Also looking to widen the front track by about the same 40mm, want to know what the best front suspension setup would be and not to expensive
philk
Postby Burning Angel » Sun Oct 19, 2008 8:22 pm
i used a corona diff(t series) which is about 100mm wider total, so 50mm each side. you can get away with it if you use front wheel drive offset wheels like +35 or more.
i am running 15x7 +8 so i had to go with big flares:
i also run gx60 struts in the front but thats alot of f&*king around and i would not recommend it.[/img]
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby philk » Mon Oct 20, 2008 9:50 pm
Thats exactly what I'm after. :)
I'm running the wide body kit and very wide wheels.
Have you got any more details on what I would have to do?
What are those struts out of?
I'm prepared for a bit of stuffing around with it.
philk
Postby soopachargen » Tue Oct 21, 2008 6:40 pm
does the sigma lower arm trick as used in ae86's and ke70's in australia work on starships?
When in doubt, down and out.
soopachargen
Postby philk » Tue Oct 21, 2008 10:01 pm
Not to sure, I have put an ex lancer 8 bolt non lsd disc brake rear end in at the moment, this has been borrowed from a mate, has made the track 60mm wider, that's the min I need could go 70mm wider
philk
Postby d1 mule » Tue Oct 21, 2008 11:07 pm
i dont no how wide a starly diff is but i measured my AE86 diff today and from mounting surface to mounting surface its 140.7cm
itll be up 4 sale once i find a suitable "F" series diff
d1 mule
Postby Burning Angel » Wed Oct 22, 2008 9:01 am
soopachargen wrote:does the sigma lower arm trick as used in ae86's and ke70's in australia work on starships?
nah the starlet has a funny front arm.
here vs the gx60 one:
the starlet has no separate radius rod, the swaybar doubles as a swaybar and radius rod.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
