postfach wrote:When I bought my 3 puck clutch it came with a pretty soft pressure plate. Because the surface area of the clutch plate is lower, the clamping force can also be lower and retain the same (or more) actual "grip" (friction). At least, thats what I've been told by my clutch guy + read.
So yes, the pedal will probably feel softer than a factory clutch.
As a side note, perhaps this is why some people find puck clutches awful on the street? If you used a puck clutch with a really heavy pressure plate it would = a huge amount of friction = really "bitey", not much finesse.
