exedy 5 puck clutch
exedy 5 puck clutch
Postby avinesh » Sun Nov 30, 2008 3:29 pm
Are the 5 puck clutch kits suppose to move a soft clutch pedal.....i got one for my r154 box running in my jza80 supra an the paddle is really really soft......i r154 is pull type but the previous owner had modified it to work as a push type so im running the push type set up an the pressure plate came with the clutch from exedy.....
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby Py7h0n » Mon Dec 01, 2008 1:30 pm
Pressure plate is where the pedal force comes from.
R154 with a push style clutch sounds wonky though.
Py7h0n
Postby postfach » Mon Dec 01, 2008 11:27 pm
When I bought my 3 puck clutch it came with a pretty soft pressure plate. Because the surface area of the clutch plate is lower, the clamping force can also be lower and retain the same (or more) actual "grip" (friction). At least, thats what I've been told by my clutch guy + read.
So yes, the pedal will probably feel softer than a factory clutch.
As a side note, perhaps this is why some people find puck clutches awful on the street? If you used a puck clutch with a really heavy pressure plate it would = a huge amount of friction = really "bitey", not much finesse.
postfach
Postby avinesh » Tue Dec 02, 2008 12:33 am
postfach wrote:When I bought my 3 puck clutch it came with a pretty soft pressure plate. Because the surface area of the clutch plate is lower, the clamping force can also be lower and retain the same (or more) actual "grip" (friction). At least, thats what I've been told by my clutch guy + read.
yea the thing is my car is suppose to have near 400wkw...goin to dyno tomorow to get it tuned will the pressure plate hold up??? i hope so coz the guys who installed it are confident it will work....
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby MrDori » Tue Dec 02, 2008 9:08 pm
ive got the exedy kits such as that, peddle is pretty springy and plate is rather bitty, not to soft tho
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
