MAGN1T wrote:If you want the job doing properly, you'd be better to solder it.
fivebob wrote:MAGN1T wrote:If you want the job doing properly, you'd be better to solder it.
Then perhaps you can explain why most mil-specs specify crimp only for unsupported connections, and why the Toyota repair document in the link above only specifies crimping for repairs???
matt dunn wrote:and try to find a solder joint in a modern car, all in-loom conections are crimp only.
Rick wrote:matt dunn wrote:and try to find a solder joint in a modern car, all in-loom conections are crimp only.
And I thought the same, but I found a solder join (there maybe be more)in the loom of an AE111.
