Where to find crimps for engine looms?
Postby ChaosAD » Tue Feb 24, 2009 8:41 pm
Im doing an engine conversion and need to join a few wires in the loom.
I want to crimp the wires as soldering doesnt seem like the best idea (especially on the thick starter wires).
Does anyone know of anywhere that sells the crimps as used in the factory toyota looms? They look like then end of an uninsulated crimp. I think theyre called a 'roll-in' type crimp?
Tried Narva and utilux but cant find anything.
ChaosAD
Postby rollaholic » Tue Feb 24, 2009 8:56 pm
i got a few big terminal type ones from repco the other day (ie the terminal that bolts onto the starter)
they might have some for joining too
Postby AE92blktop » Tue Feb 24, 2009 10:00 pm
if you want big un insulated crimps try your local electrical wholesale, they will have a good selection but you may need something better than a pair of pliers or those ones you use on the red, blue and yellow crimps.
AE92blktop
Postby Rick » Tue Feb 24, 2009 10:48 pm
I just use uninsulated spade terminals and cut off the spade end, you do need to use a proper crimper to close up the crimps tho.
Postby ChaosAD » Tue Feb 24, 2009 10:56 pm
Yea those are the ones. Ive got a cheap utilux 'roll-in' crimper like pictured, just cant find the crimps.
Cutting the end off should work for the sensors etc, but need something bigger for the power wires and starter wire.
ChaosAD
Postby GTCRSHR » Tue Feb 24, 2009 11:27 pm
where in nz do you get the proper molex ones as you ahve pictured above ?
Nothing to see here ...
GTCRSHR
Postby NZ_AE86 » Wed Feb 25, 2009 9:00 am
Most Auto-electrical workshops should carry some. You need to use proper crimpers for them - they look like bolt cutters - or you could just run a new cable for the starter? (this would be the best option)
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby GTCRSHR » Wed Feb 25, 2009 9:41 am
i have proper crimpers from the uK,
where to buy in bulk tho, im not buying 50 packs of 5or 10 and getting screwed cause you cant buy in bulk,
any ideas? sorry for hijacking
GTCRSHR
Postby GTCRSHR » Wed Feb 25, 2009 9:47 am
http://www.jimruffi.com
that guy has a good selection, i havent been in touch yet
GTCRSHR
Postby evil_si » Wed Feb 25, 2009 9:57 am
rs components
gt south rd in penrose, think they have an online catalogue as well
rscompnents.com
evil_si
Postby fivebob » Wed Feb 25, 2009 9:58 am
Postby jaypines » Wed Feb 25, 2009 11:19 pm
dont know if toyota sells them but here are some wiring infos and P/Ns
click here **5mb file
confirm if toyota sells them... :wink:
jaypines
Postby MAGN1T » Thu Feb 26, 2009 8:57 am
If you want the job doing properly, you'd be better to solder it.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby fivebob » Thu Feb 26, 2009 9:07 am
MAGN1T wrote:If you want the job doing properly, you'd be better to solder it.
Then perhaps you can explain why most mil-specs specify crimp only for unsupported connections, and why the Toyota repair document in the link above only specifies crimping for repairs???
Postby Adydas » Thu Feb 26, 2009 9:51 am
J a Russell, Ideal and Coreys Electrical all stock those off the shelf, If you still need them give me a PM as i work at one of those fine establishments and can help ya out.
Adydas
Postby sergei » Thu Feb 26, 2009 10:25 am
I say crimp it with a longish crimp and put a solder down the middle.
Postby Adydas » Thu Feb 26, 2009 4:19 pm
i should have done this before but got a bit busy, but ill move this to General as it not really a technical question
Adydas
Postby matt dunn » Thu Feb 26, 2009 11:00 pm
and try to find a solder joint in a modern car, all in-loom conections are crimp only.
Postby Rick » Thu Feb 26, 2009 11:13 pm
matt dunn wrote:and try to find a solder joint in a modern car, all in-loom conections are crimp only.
And I thought the same, but I found a solder join (there maybe be more)in the loom of an AE111.
Postby matt dunn » Thu Feb 26, 2009 11:21 pm
interesting as I have pulled a few loom to bits lately and they have all had crimps in them.
