ke36 sr coupe diff?
ke36 sr coupe diff?
Postby Infinite » Thu Mar 26, 2009 6:33 pm
The diff in my sr has a solid unboltable head in it? is this normal? to *remove* the head u take the internals apart from the back.... will a ke35 diff be able to replace the whole thing?
Lots
Infinite
Postby l1ttle_d3vil » Thu Mar 26, 2009 6:44 pm
huh? you pull the backing off the diff housing?
the diff head should unbolt by 8 or 10 bolts on the front (driveshaft side) of the diff housing.
Postby Infinite » Thu Mar 26, 2009 6:49 pm
yea it dont tho.... O_o im about to go get pics....
Lots
Infinite
Postby Infinite » Thu Mar 26, 2009 7:12 pm
pics!!!
as u can see in the last pic spider gears are welded :(
Lots
Infinite
Postby l1ttle_d3vil » Thu Mar 26, 2009 7:33 pm
definitely a different diff fitted...no idea what though
Postby fangsport » Thu Mar 26, 2009 7:51 pm
looks like a Borg Warner.
maybe from aussie assembled corona wagon with 1S motor
fangsport
Postby 79rolla » Thu Mar 26, 2009 8:24 pm
i recon it coul be out of a datsin or escort?
just with a quick look on tm the only diffs like that are ford or holden/gm
past: AE82 FXGT
79rolla
Postby fangsport » Thu Mar 26, 2009 9:08 pm
is the diff fasteners Metric or Imperial?
has the stud pattern been modified?
would narrow the possibilities down
fangsport
Postby Infinite » Fri Mar 27, 2009 7:47 am
after talking to alot of people last night fangsport is half correct its a borg warner from an aussie ke36... so chances of geting another diff like it are slim so just gona put a ke30 diff in!. but i need a new dshaft to as the bolt pattern is different...
Lots
Infinite
Postby rwd_mayhem » Fri Mar 27, 2009 11:04 am
fangsport wrote:looks like a Borg Warner.
Yea thats what i have in my SE, it looks the same (except springs etc)
EDIT: Oh you figured it out. just drill new holes in the driveshaft flange for the 30 diff.
current: 1975 Valiant Regel
rwd_mayhem
Postby jakesae101 » Fri Mar 27, 2009 11:44 am
79rolla wrote:i recon it coul be out of a datsin or escort?
not quite an escort diff but looks similar to a atlas or narrow atlas capri diff but doesnt have enough blot holes on the rear plate
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Users browsing this forum: Google [Bot] and 24 guests
