Mr Revhead wrote:Does your Hiace look like a work hiace
or a boys hiace. Ie tints and slammed
d1 mule wrote:Mr Revhead wrote:Does your Hiace look like a work hiace
it had mags on the front and bickies on the back,
durty starlet wrote:d1 mule wrote:Mr Revhead wrote:Does your Hiace look like a work hiace
I would say your $&#$% probly lol
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
Girvs wrote:In short the facts were you did a burnout, you got caught while doing it, you admitted you were guilty. You may as well admit you were guilty in court and get it over with as everything is stacked against you.
sergei wrote:There is one Road Code adjustment I would welcome: fine/demerit people blocking right lanes.
Girvs wrote:sergei wrote:There is one Road Code adjustment I would welcome: fine/demerit people blocking right lanes.
Not sure where it says there is a fast lane in the road code. AFAIK motorways and so forth are all rated to 100Km/h hence any lane can be used for speeds upto 100Km/h. Its only courtesy that you are to pull to the left (unless signs state otherwise). But back on topic...
Girvs wrote:Its only courtesy that you are to pull to the left (unless signs state otherwise). But back on topic...
