Buyer Advice Needed SW20 3SGTE MR2
Postby FANGIN » Mon Nov 30, 2009 2:44 pm
Tonight my flatmate is looking at a 3SGTE powered SW20 targa top. Done 180xxx kms
What are the common faults to look for on these?
Will be looking for the obvious but is there anything we should be especially looking for?
Cheers guys
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Re: Buyer Advice Needed SW20 3SGTE MR2
Postby sergei » Mon Nov 30, 2009 2:54 pm
FANGIN wrote:Tonight my flatmate is looking at a 3SGTE powered SW20 targa top. Done 180xxx kms
Cheers guys
Coolant related issues: rust in cooling system (crunchy hoses), overheating, water in oil (milky oil), which brings to another common problem:
Oil related issues: sludge (black plastic like build up under rocker cover), run bearings and oil leaks which brings to another problem:
Blown turbo seals.
Postby sergei » Mon Nov 30, 2009 2:55 pm
Oh, since Targa Top - it will be leaky.
Postby FANGIN » Mon Nov 30, 2009 2:57 pm
Yea will be looking for all of those. Any common 3sgte problems tho?
FANGIN
Postby sergei » Mon Nov 30, 2009 3:02 pm
FANGIN wrote:Yea will be looking for all of those. Any common 3sgte problems tho?
Ran bearings and blown head gasket from result of neglect (first from running low on oil, second from running on water or old coolant).
Postby FANGIN » Mon Nov 30, 2009 3:04 pm
FANGIN
Postby Akane » Mon Nov 30, 2009 3:30 pm
Whatever you do, don't buy a pre facelift.
Postby FANGIN » Mon Nov 30, 2009 3:40 pm
And the reason for that would be?
Which year did the facelift model come out?
FANGIN
Postby Akane » Mon Nov 30, 2009 4:56 pm
a completely better designed head
Better cams on both intake and exhaust
better turbo
better injectors
different ECU
Map sensored
better exhaust manifold
better sump
better oil filter location
Revised PCV
Better oil pump IIRC (Or was it waterpump?)
better headgasket
better a million other bits.
the list goes on.......
it would be late 93 / 94 and newer for post facefilt.
Some people don't really care about these little bits and pieces of better things, but if I can choose again, I'd go for a facelift.
Postby kim0663 » Mon Nov 30, 2009 5:06 pm
you forgot to add that the owners usually want more than your arm and leg and some more for the facelift ones :lol:
1992+ would be my choice. Got all the goodies except the engine changes and only costs a finger
Oh and one more thing, being targa top... many people tend to sell them again when winter comes. You do the maths.
Mr2 GT-S
330ci M
kim0663
Postby Akane » Mon Nov 30, 2009 5:33 pm
The 92 has none of the goodies I've mentioned.
They want an arm and a leg for the facelift for a reason. Because they are that much better if you don't plan to go "all out" and " I'm gonna replace everything with aftermarket parts anyway.".
Postby kim0663 » Mon Nov 30, 2009 5:35 pm
ah true. my bad.
I thought it listed various things in that long list i didn't bother to read :oops:
Mr2 GT-S
330ci M
kim0663
Postby Adamal » Mon Nov 30, 2009 5:57 pm
Safest bet: Just don't get one. They're a pain when things go wrong :P
Postby Akane » Mon Nov 30, 2009 6:36 pm
Adamal wrote:Safest bet: Just don't get one. They're a pain when things go wrong :P
Exactly, wish I bought a sweet 180SX instead...... at least I won't kill my back everytime I worked on it.
Postby Adamal » Mon Nov 30, 2009 10:24 pm
Back, and all those muscles down the back of your leg......
Postby Akane » Mon Nov 30, 2009 10:51 pm
And your stomach when you stand on a chair to lean down into the engine bay, that wedge is nice looking and all but it kills me.
Postby fivebob » Mon Nov 30, 2009 11:03 pm
Wimps :lol:
Try bench pressing the gearbox about 10 times because you don't have a proper alignment tool for your twinplate clutch. Must admit I got pretty good at it, only took one attempt and about 30secs to see if I'd got the splines aligned correctly.
Postby Adamal » Mon Nov 30, 2009 11:28 pm
You didn't follow the golden rule: Everything is an engine out job :P
Postby fivebob » Mon Nov 30, 2009 11:30 pm
Adamal wrote:You didn't follow the golden rule: Everything is an engine out job :P
Nah, that would've made the job harder. Gearbox is an easy one to do on it's own, I just complicated it by fitting a twin plate clutch. ;)
Postby FANGIN » Tue Dec 01, 2009 7:40 am
Cheers for the info guys, was a pre facelift, I ended up not going with him to get it, but gave him a heads up. I thought they would be a bit quicker than what they are.
FANGIN
