thornz wrote:A set of these would look mint on a black MR2, probably way out of your price range though
http://www.magandturbo.com/pages/wheel. ... 1716974278
tsoob wrote:The TSR wheels are only available through the enemy, I cannot supply them to you.
Drift tek is the water but wont be till the 20th of janurary.
THA SHZ wrote:tsoob wrote:The TSR wheels are only available through the enemy, I cannot supply them to you.
if you need help getting them nick i can help u
MR2BOY23 wrote:Heres the 17X10 on the rear and 17X9 on the front
tsoob wrote:the only way you could run a 10 would be with a widebody kit and a low offset wheel 10-20p
Adamal wrote:What are you talking about, Al ya doofus. Thats like saying you could get a 13" wide wheel with stock guards on the back of an MR2. With the right offset.
Offset does not change the amount of available space between the strut tower and the guard on a car
Al wrote:Yeah I was reading on mr2oc.com that you want something like a +20 offset for the rear with a widebody with a 10" rear wheel to just sit under flush so if you get rub you don't crack the kit.
