The Wheel Suggestion Thread
Postby tsoob » Mon Dec 21, 2009 10:48 am
id suggest test fitting if its just a guess.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby tsoob » Mon Dec 21, 2009 10:52 am
The TSR wheels are only available through the enemy, I cannot supply them to you.
Drift tek is the water but wont be till the 20th of janurary.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby thornz » Mon Dec 21, 2009 10:58 am
A set of these would look mint on a black MR2, probably way out of your price range though :P
http://www.magandturbo.com/pages/wheel. ... 1716974278
thornz
Postby tsoob » Mon Dec 21, 2009 11:11 am
thornz wrote:A set of these would look mint on a black MR2, probably way out of your price range though :P
$4000+ gst,
I have a set on the water at the moment for one of my customers.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby THA SHZ » Mon Dec 21, 2009 11:17 am
tsoob wrote:The TSR wheels are only available through the enemy, I cannot supply them to you.
if you need help getting them nick i can help u 8)
THA SHZ
Postby MR2BOY23 » Mon Dec 21, 2009 12:05 pm
Heres an example of a black mr2 with ssr wheels, similar to work meister
Might need a bodykit to pull it off though
And an example here of what it may look like if I paint the my current wheels
MR2BOY23
Postby tsoob » Mon Dec 21, 2009 12:57 pm
u sure? I spoke to brad today and they have brought all the stock
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Adamal » Mon Dec 21, 2009 1:48 pm
MR2BOY23 wrote:Heres the 17X10 on the rear and 17X9 on the front
Highly unlikely.
Just bought some 17x8.5 for the front and 17x9.5 for the rear. They come flush with the guards and just miss the struts. And thats on the widebody MR2.
Postby Al » Mon Dec 21, 2009 2:50 pm
Widths mean SFA without offset.
Kinda like 1/4 mile times without trap speed and 60ft.
Al
Postby Adamal » Mon Dec 21, 2009 3:16 pm
What are you talking about, Al ya doofus. Thats like saying you could get a 13" wide wheel with stock guards on the back of an MR2. With the right offset.
Offset does not change the amount of available space between the strut tower and the guard on a car :P
Postby iOnic » Mon Dec 21, 2009 3:24 pm
The sort of offset you would need to run on a 10" wide wheel to keep it under the stock guards would result in the wheels rubbing on the struts (even with adjustable coilovers).
This is my rear fitment. About 10-15mm away from the strut and 10-15mm away from the guard even with my weak offset (+35/+40 :oops: ) I'd hate to try and fit a wheel almost 3" wider in there :lol:
Postby tsoob » Mon Dec 21, 2009 3:54 pm
the only way you could run a 10 would be with a widebody kit and a low offset wheel 10-20p
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby soopachargen » Mon Dec 21, 2009 5:15 pm
tsoob wrote:the only way you could run a 10 would be with a widebody kit and a low offset wheel 10-20p
haha, dont tell the americans that
When in doubt, down and out.
soopachargen
Postby soopachargen » Mon Dec 21, 2009 5:49 pm
have a play with this for wheel and tyre sizes http://mr2.gordaen.com/wt_calc.php
soopachargen
Postby Al » Mon Dec 21, 2009 8:33 pm
Adamal wrote:What are you talking about, Al ya doofus. Thats like saying you could get a 13" wide wheel with stock guards on the back of an MR2. With the right offset.
This is true, but had you done some research you would see that 10.5" wide rears have been fitted to the rear of stock bodied mr2s, with some rolling of the guards of course, a stretched tire and some neg camber :)
Your 9.5" rears with the widebody is far too conservative considering this guy is running 18x10s on the rear with a 37 offset and stock body, tire is a 235/35 :) Allegedly only big bumps rub because of no guard rolling.
Al
Postby Adamal » Mon Dec 21, 2009 10:11 pm
Mine are like a 38 offset from memory. Sit about 2mm off the strut and are flush with the rear guard :P
Postby Al » Mon Dec 21, 2009 10:42 pm
Yeah I was reading on mr2oc.com that you want something like a +20 offset for the rear with a widebody with a 10" rear wheel to just sit under flush so if you get rub you don't crack the kit.
Al
Postby tsoob » Tue Dec 22, 2009 9:21 am
Al wrote:Yeah I was reading on mr2oc.com that you want something like a +20 offset for the rear with a widebody with a 10" rear wheel to just sit under flush so if you get rub you don't crack the kit.
what i said.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby MR2BOY23 » Tue Dec 22, 2009 4:51 pm
MR2BOY23
Postby fuel » Tue Dec 22, 2009 9:49 pm
not feelin them sorry, in my opinion I think they're a step down from your current rims
LOUD NOISES!!!
fuel
