NOLAW wrote:need to drop the compression as iv gone turbo, and the compressions to high to run anymore than around 10psi and iv been told even then that could be pusing it
sergei wrote:Thicker head gasket does not help with detonation. Even if you drop compression via headgasket, you are removing squish areas which increases detonation.
NOLAW wrote:i got 145kw on 5psi and was told the compression was rather high by brent at dynopower (200 on each cylinder) and he reconed i would only be able to run 10psi and even then that would be pushing it and i want to run about 15psi and no its running a link g3 with electronic boost control.
I think the compression on the late model gze's is about 8.9:1, is this to high to run 15psi on?
NOLAW wrote:from what i know of it hasnt been skimmed but i could be wrong, what are other compression readings people have had from there gze's if theres anyone else out there whos had it done?
NOLAW wrote:yeah well the whole compression thing is all new to me so thats why im asking for advice and trying to get to grips on how it all works and what i should do
