Oil Cooler Set up
Oil Cooler Set up
Postby 1I1 » Sat Jun 05, 2010 11:49 am
I pretty much have everything stting at home waiting to go in, however after speaking to togue_trueno i'm a bit unsure if it will be sweet.
This is the intended setup:
Made using my awesome paint skills
The issue i need to check if there will be one, is there a chance that oil will drain out? I don't fancy having to build pressure everytime i go to drive it
TRD Clicky >>Here
1I1
Postby AE82 FXGT » Sat Jun 05, 2010 4:28 pm
Wouldn't you want the filtered oil going through the cooler?
AE82 FXGT
Postby sark.inc » Sat Jun 05, 2010 6:25 pm
if i am reading it right. it looks like oil could drain back in to the sump.
thats how it should be setup if i am right, so you can use the filters anti drain back valve to stop oil going back in to sump, it's also filtered oil as well.
sark.inc
Postby d1 mule » Sat Jun 05, 2010 7:15 pm
go out of the block, through the filter, out of the filter into the "hot" side of the cooler core, out the "cold" side back into the block.
doesn't drain back to the sump!
ill take pics of my set-up if you want
d1 mule
Postby sark.inc » Sun Jun 06, 2010 2:32 am
so like my picture :D?^
sark.inc
Postby 1I1 » Sun Jun 06, 2010 9:22 pm
Darn, just realized my picture is slightly wrong in that it's not a remote filter setup. The adaptor goes between the engine block and filter
TRD Clicky >>Here
1I1
Postby touge_ae101 » Mon Jun 07, 2010 10:34 am
hey mark did you see this thread viewtopic.php?t=63527&highlight=oil+remote
but if you want to filter it first, go filter->bottom of cooler->out top of cooler back to block.
this way only the oil from the line from top of cooler to block will drain which will prob be SFA. and because it is filtered first, teh anti drainback will stop the oil in the cooler draining back. :lol:
i think this is only a issue cause you are running the cooler vertically, i'm not even going to worry bout this with my setup. it is the same principle as using a remote setup.
touge_ae101
Postby bluemaumau » Mon Jun 07, 2010 6:20 pm
i was under the impression you run cooler - filter - block. this way the filter is the last thing, (thus filtering everything). but the drain back sounds like an issue
might have to have a look at my setup
Postby 1I1 » Fri Sep 03, 2010 1:59 pm
Thread revival
Starting to actually get motavation to fit everything up. When i go to mount the cooler core should i be solid mounting it or using some sort of rubber bushes to insulate it to help reduce vibrations from the car onto the cooler?
TRD Clicky >>Here
1I1
Postby Bazda » Fri Sep 03, 2010 5:23 pm
1I1 wrote:Thread revival
Yes you should sit the cooler on little rubber standoffs. Ones with 6mm threads sticking out of them would be ideal is most cases.
Postby 1I1 » Fri Sep 03, 2010 5:41 pm
Sweet, after posting this i spoke to our service manager and he recomended it be best to use cotton real style bushes.
Oldly the Trust kit that I'm basing my setup off solid mounts the cooler
TRD Clicky >>Here
1I1
Postby captain crescent » Fri Sep 03, 2010 8:15 pm
i think you should just stop procrastinating and fit it on your car
captain crescent
Postby touge_ae101 » Fri Sep 03, 2010 9:42 pm
bones on bikes wrote:i think you should just stop procrastinating and fit it on your car
seconded! :lol:
touge_ae101
Postby sergei » Fri Sep 03, 2010 10:18 pm
if you use braided hoses don't solid mount it. Alloy does not like vibration.
Postby 1I1 » Mon Sep 06, 2010 8:59 am
seconded! :lol:
oi work did start yesterday!
TRD Clicky >>Here
1I1
Postby captain crescent » Mon Sep 06, 2010 6:31 pm
woooow so thats why we have bad weather and flooding!!!!
captain crescent
Postby touge_ae101 » Mon Sep 06, 2010 6:34 pm
not at my house, you must be in chch. (well not inside) :P
touge_ae101
Postby 1I1 » Fri Sep 16, 2011 4:52 pm
And a year later it's still sitting in the shed waiting to be fitted.... :oops: Fingers crossed it'll be fitted over the next couple weekends though.
But:
Whats the deal with oil changes? Have done some searching on here but netted nothing. Will I need to pull everything apart and flush the lines/core or just replace what ever drains out of the sump and filter?
TRD Clicky >>Here
1I1
Postby 2LTR Rona » Fri Sep 16, 2011 5:23 pm
no different to an oil change without an oil cooler
2002 Altezza, 1974 KE25
2LTR Rona
