This is the intended setup:
Made using my awesome paint skills
The issue i need to check if there will be one, is there a chance that oil will drain out? I don't fancy having to build pressure everytime i go to drive it
1I1 wrote:Thread revival
Starting to actually get motavation to fit everything up. When i go to mount the cooler core should i be solid mounting it or using some sort of rubber bushes to insulate it to help reduce vibrations from the car onto the cooler?
touge_ae101 wrote:bones on bikes wrote:i think you should just stop procrastinating and fit it on your car
seconded!
