MrOizo wrote:Well! I have tracked down the transistor. After finding it i realised that sergei pointed me straight to it! I cant believe how awesome you are sergei!
I started thinking that T707 was the type of transistor that i needed to find(not its location)
Done some more looking around and T707 has 734 331A. I think that the 331A is right. looks like some paint is covering the labeling. Is this something Toyota does so it cant be repaired easily?
sergei wrote:http://doc.chipfind.ru/nec/2sb734.htm
So it is a 2SB734
MrOizo wrote:sergei wrote:http://doc.chipfind.ru/nec/2sb734.htm
So it is a 2SB734
How the hell did you find that??So the original line you gave me for RS is all good still?
Cheers.
MrOizo wrote:Ok I think I'm already wrong - C in the centre one right?
If I keep the writing the same way as the others I should be sweet right?
Had info on how to find which one was which one was which but lost that info
sergei wrote:MrOizo wrote:Ok I think I'm already wrong - C in the centre one right?
Yes, writing is the key. Just keep the writing same way.
MrOizo wrote:Actually thinking about it now, the ECU is earthed on the Intake Manifold right?Well i know there are earths on the manifold - I'll go with that for now
Users browsing this forum: Bing [Bot] and 17 guests
