Beams 3sge vs Sr20det vs 3tgte
Postby shihad » Mon Nov 15, 2010 11:35 pm
probally not viable cost wise but I have always thought a carina was the perfect size for a 1ggte...
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby RomanV » Mon Nov 15, 2010 11:50 pm
Truenotch wrote:
RomanV wrote:As in, theoretically I know where the hole is, I know what I'm supposed to plug it with, but that's about it?
:lol:
Well in this case you actually had a hole to plug, but didn't go there 8O .
Well actually, I prefer not to plug the hole because I like how fluid gushes out of it, onto my head.
:o
2RZFE with a turbo anyone
I swear that just about every type of engine known to man, has been shoe horned into a carina... 3RZ though.
Postby fuel » Mon Nov 15, 2010 11:57 pm
just putting this out there
LOUD NOISES!!!
fuel
Postby Truenotch » Tue Nov 16, 2010 12:00 am
RomanV wrote:Well actually, I prefer not to plug the hole because I like how fluid gushes out of it, onto my head.
... Sounds like there's something wrong with your head?
Truenotch
Postby Emperor » Tue Nov 16, 2010 7:28 am
Babz wrote:
13b - too expensive to maintain and build but always wanted one
Sigh..... :roll:
It's only expensive if you choose the wrong engine builder.
Mine's lasted 4 years so far with no issues, the only thing i've done to it is oil changes.
Link G3, Exhaust, Intake, S6 housing, S5 rotors(high comp). Around 240KW.
So maintenance = $80 oil change
Emperor
Postby Babz » Tue Nov 16, 2010 3:27 pm
See now i feel like going rotary :? what to do?
Babz
Postby Bling » Tue Nov 16, 2010 3:34 pm
Check your bank balance and go from there :lol:
I'd work out what sort of animal you want under the hood. Every engine is going to deliver a different feel. Me... i'd like a 1UZ in my corona, why though I have no idea.... its a V8 is all I have right now :lol: But yeah, not sure what i'll end up with, but I prefer revving the living shit out of engines, so not sure which will suit me 8) Hell I might just be 'boring' and go 4AGTE. No point being different if its going to cost you more for the same result.
So yeah, bank balance will dictate a bit and what work you can do yourself if any :)
Postby TRD Man » Tue Nov 16, 2010 4:44 pm
Of the 3 engines you've indicated you're choosing between, and your desired power output, the turbo SR20 is the only realistic option.
You simply won't get there with a 3SGE and if choosing between two turbo engines/drivetrain combos why wouldn't you use the more modern with more readily available and reasonably priced components?
TRD Man
Postby Babz » Tue Nov 16, 2010 6:26 pm
i was trying to get a hold of Scott form fraser today but he was always out. try again tomorrow. If he is able to put a gen 3 3sgte motor in then i will go that way, provided it is not much more then getting a SR20 in there.
Anyone know a good place to get nolathane bushings done? I have all my front and rear off. Also has anyone done a camber mod on a AA60 or ta63 or tt141 etc with the IRS. I know you have to add on another adjusting bolt and drill out the hole , but exactly where i do not know.
[/list]
Babz
Postby al_feinted » Tue Nov 16, 2010 9:11 pm
Hi, Ive done the camber mod on my corona. Heres a few pics of the finished product.
The bolts I used were bought new from BMW (around $60 for the set!!) i think they are from a M5.... there must be other cheaper options out there.
bmw part numbers :
33-32-1-095-102 ECCENT-BOLT
33-32-1-092-310 ECC-WASHER
33-32-6-751-446 NUT
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
al_feinted
Postby Babz » Tue Nov 16, 2010 9:26 pm
Thats awesome mate. thanks for that. Were you able to dial it back close to Zero after lowering it?
1982 Carina TA63 (in the making)
1986 Corona TT141 SR20DE (Rear Ended and For Sale)
1998 Audi A3 1.8T (wifes daily driver)
2011 Mitsubishi Triton (Work Ute)
Babz
Postby al_feinted » Tue Nov 16, 2010 9:55 pm
No problem. From memory I got 0.5 degrees on one side and 1.5 degrees on the other on the lowest setting (not sure why the difference i guess i cant weld straight). A massive improvement over the 3-4 degrees you can end up with after lowering.
www.toycrazy.net
al_feinted
Postby FANGIN » Wed Nov 17, 2010 9:37 am
Hate to be a hater - SR20. Best bang for buck.
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby Mr Revhead » Wed Nov 17, 2010 11:11 am
TRD Man wrote:Of the 3 engines you've indicated you're choosing between, and your desired power output, the turbo SR20 is the only realistic option.
Either that.
Or which ever gives you the biggest hard on
Postby 4agtepwr » Wed Nov 17, 2010 9:57 pm
Its sooooo easy to make 400 reliable hp out of an vct s14/s15 sr20. Its also not that hard to make the same out of a 3S but a bit more costly to do the rwd thing i guess. Id go sr20 even though im a fairly staunch toyota man there pretty hard to beat
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby fangsport » Wed Nov 17, 2010 10:35 pm
2/3RZ..................... no substitute for cubes when building ponies.
plenty of support for silly behaviour from the same guys that build pushrod motors that embarrass the hell out of technology down US 1/4's :wink:
fangsport
Postby Adamal » Wed Nov 17, 2010 11:45 pm
FANGIN wrote:Hate to be a hater - SR20. Best bang for buck.
Yea. SR20DET will be easier to hit 250hp than a 3SGE BEAMS, cheaper, will be less strained and give you more mid range torque.
Postby tsoob » Thu Nov 18, 2010 12:08 am
13 B is the coolest option.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby h8wrxs » Thu Nov 18, 2010 12:27 am
fuel wrote:just putting this out there
definitely
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Babz » Thu Nov 18, 2010 6:50 am
So no one thinks i should be doing a 3T-EU turbo setup? Has anyone had any experience with this setup here? Just to be different.
http://www.bigflea.com/corolla/images/tonynegron5.jpg
Babz
