20v silvertop wont idle
Postby h8wrxs » Sun Jan 02, 2011 10:46 pm
im having problems with my 20v silvertop 4age
i went to fit a new aftermarket intake plenum to it tonight and got it all bolted up
the problem is there is 2 air lines/vacuum lines coming out of the bottom of the stock one that my aftermarket one doesnt
i was told when i bought it neither was important and didnt need to be re-tapped into the new one
but now my car doesnt idle at all, with a screwdriver in the airflow meter holding the flap open it runs but not without it
does anyone know what these lines do/are for? ive tried blocking them etc and nothing gets it running?
i can put up pics if anyone wants me to
any help would be much appreciated
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby whynot » Sun Jan 02, 2011 10:50 pm
the little hose may be for the power steering idle up (not sure). but the big one is for the idle control solenoid so they need to be plumbed back into the intake after the air flow meter for it to be happy
whynot
Postby h8wrxs » Sun Jan 02, 2011 10:52 pm
but why would they not run off atmospheric air if it will inside the stock plenum?
i ws thinking of just putting a little air filter on the big hose but tht didnt work?
h8wrxs
Postby whynot » Sun Jan 02, 2011 10:58 pm
the problem is that it is sucking air without it passing through the air flow meter so the ecu is not giving the motor enough fuel. basically a vaccum leak. you could get away with it on a blacktop 20v because it has a map sensor not an afm.
just bung them in the intake pipe going from the afm to your new plenum and it will work fine.
whynot
Postby h8wrxs » Sun Jan 02, 2011 11:22 pm
is it possible to convert a silvertop from an airflow meter to a map sensor?
h8wrxs
Postby whynot » Mon Jan 03, 2011 9:59 am
you can remove the airflow meter by either fitting an after market ECU or fitting the engine loom, ECU and map sensor from the 20v blacktop motor.
there was a post recently on the blacktop ecu swap with some info on pinouts which will help if you go down that path. http://forums.toyspeed.org.nz/viewtopic.php?t=81282
[/img]
whynot
Postby Lloyd » Mon Jan 03, 2011 11:25 am
Just fix the leak
A vacuum leak on a MAP sensor engine will give issues just as it will on an AFM engine, though with AFM you get the idle issues moreso.
Postby h8wrxs » Mon Jan 03, 2011 11:28 am
well ive got it running now, thanks for the info
will probly end up doing a bt conversion one day anyway
h8wrxs
