Has this fuel gone bad?
Postby cat007 » Wed Jan 12, 2011 12:28 pm
It's been sitting in the tank for over a year and has gone a very yellow/orange colour. Here's a pic:
Postby cozmoid » Wed Jan 12, 2011 12:33 pm
Looks like some one peed in your fuel tank! 8O
If it has changed colour that significantly I would say it is very bad. Fuel only lasts around 6 months at best I think, even worse for av gas
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby tsoob » Wed Jan 12, 2011 12:59 pm
chuck a match in it and see :wink:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bling » Wed Jan 12, 2011 1:17 pm
Tank is probably rusty or something?
Good lawn mower fuel 8)
Postby cat007 » Wed Jan 12, 2011 2:29 pm
cozmoid wrote:Looks like some one peed in your fuel tank! 8O
Yeah I think it's a bit naffed. Probably the main reason the supra won't start. Initially thought it was the injectors not getting power, fixed that. Then the fuel pump wasn't working when cranking, fixed that. Now hopefully this bad fuel is the last of the problems. Then I should be good to go for some launch control burnouts in the drive hehe
Postby sergei » Wed Jan 12, 2011 3:11 pm
It pays to pull out the injectors and put couple of drops of acetone on the tips, if you think injectors don't fire because of gunked up fuel in them...
Postby cat007 » Wed Jan 12, 2011 4:04 pm
tsoob wrote:chuck a match in it and see :wink:
Haha dammit I didn't think about that until I tipped it on the neighbours cat
Oh well. Next time :)
Postby matt dunn » Wed Jan 12, 2011 6:36 pm
I'd say 98 goes off faster than avgas, well looses it's quality anyway.
but rare to find some gas that has got to the point it wont start the car.
Postby cat007 » Wed Jan 12, 2011 7:16 pm
but rare to find some gas that has got to the point it wont start the car.[/quote]
The rarity here would be the fuel is over a year old lol
Postby pureadrenalin » Wed Jan 12, 2011 8:03 pm
cat007 wrote:The rarity here would be the fuel is over a year old lol
I got half a tank in my old mr2 that is 2 years old, just put a new engine in, ready to start it up :lol:
pureadrenalin
Postby Bling » Wed Jan 12, 2011 9:03 pm
Yeah my corona still starts up first pop on whats most likely 3 year old 91 8)
Postby cat007 » Fri Jan 14, 2011 11:46 am
sergei wrote:It pays to pull out the injectors and put couple of drops of acetone on the tips, if you think injectors don't fire because of gunked up fuel in them...
Might have to pull them out. I can't get the car to run with fresh fuel and new plugs. It fires a couple of times after about 7-8 seconds of cranking, then nothing for another 5-10 seconds.
I did manage to get it to run for about 10-15 seconds, it was running pretty rough, but it idled, then as I tried to rev it a little, it coughed and spluttered and backfired with black smoke, then died.
I don't have any acetone, what else could I use to give the injectors a clean?
Postby sergei » Fri Jan 14, 2011 12:44 pm
you can buy acetone from hardware store (mitre10, bunnings, placemakers).
Postby cat007 » Fri Jan 14, 2011 12:53 pm
Sweet - will do that.
Soak just the tips or apply power to them and pure some through?
Postby sergei » Fri Jan 14, 2011 12:56 pm
cat007 wrote:Sweet - will do that.
you could buy a syringe and force it through with power on but it is very dodgy: 1) sparks + acetone = fire 2) low impedance injectors do not work well with 12V 3) acetone destroys o-rings (outside of the injectors).
Postby cat007 » Fri Jan 14, 2011 12:59 pm
So just soak the tips then? lol
Postby sergei » Fri Jan 14, 2011 1:19 pm
cat007 wrote:So just soak the tips then? lol
yep.
You could also drip into the injector (rail end).
Postby cat007 » Fri Jan 14, 2011 1:45 pm
yep.
Might put a small hole in some duct tape, and place over the top, that should help any getting onto the o-ring
Postby cat007 » Fri Jan 14, 2011 2:55 pm
Ok so I thought I'd see if I could get it going again, see if getting some heat into everything would help...
Well it took a while but eventually it coughed into life. Although the strange thing is, it will either crank and crank coughing and firing once every 10 or so seconds, or it will crank for 1-2 seconds and idle....
I've checked the ignition timing and it seems fine. Cam timing, well, I haven't looked, but the last time it started the engine it was running fine...
Once warmish I gave it a few revs and if I abruptly open the throttle anything more than 10% it misses and backfires through the exhaust. I can rev it high in the rev range (ran it up to 5,000rpm) and it's fine as long as I only barely open the throttle....
Does this sound like gummed up injectors? I'm a little confused...
edit: Also sometimes when initially cranking, it tries to fire against the starter, but only at the start
Postby MAGN1T » Fri Jan 14, 2011 4:32 pm
You get that when ignition timing is too far advanced.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
