pros nd cons of runing a oil cooler on a 4age?
Postby 88.4ageGT » Tue Jan 25, 2011 1:22 am
was thinking about puting one one my road car nd wanted to know if others hav done this? and what they thought about it?
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby Burning Angel » Tue Jan 25, 2011 6:19 am
not really needed on a road car, but if you do put one on make sure you use an oil thermostat in the system.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Quirky » Tue Jan 25, 2011 4:38 pm
My 4ag turbo with no oil cooler doesn't get above 98 degrees c at the drag strip.
And thats 2 hours, about 10 passes.
When and if, it reaches 100 degrees, ill probably start worrying.
Hello There
Quirky
Postby Adamal » Tue Jan 25, 2011 4:44 pm
Quirky wrote:My 4ag turbo with no oil cooler doesn't get above 98 degrees c at the drag strip.
Do you take it to the track at all? Sustained heavy use may make it get hotter. Or is it a dedicated strip car?
Postby Quirky » Tue Jan 25, 2011 4:49 pm
Well here in Townsville its just a drag strip.
And yea, there are maybe 5 mins between each run.
I have taken it to the go kart track.
But thats probably only 45-50 secs and you only do 2 laps at a time.
Probably reached 105 degrees which is still pretty safe i assume.
Hello There
Quirky
Postby 1I1 » Tue Jan 25, 2011 6:04 pm
Pffff 98degrees. I was seeing 140degrees at Manfeild after just a few laps :oops:
On the street, lucky for the car to get above 110degrees.
TRD Clicky >>Here
1I1
Postby tsoob » Wed Jan 26, 2011 10:15 am
I run one on mine... But i had MAJOR heat issues, now its sweet as.
Dropped core temps by 10-15 degrees
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby touge_ae101 » Wed Jan 26, 2011 12:45 pm
i see a oil cooler as just a bit of insurance. run with a thermostat and you can't go wrong really. especially when 4ages are susceptible to run bearings so easily, you don't want your oil thinning out much.
as mark said 140deg is what you get at the track or if you are giving it a good thrash.
touge_ae101
Postby 1I1 » Wed Jan 26, 2011 1:20 pm
On the street it would never get that hot as it requires you to be reving the car to redline over and over again = not really something you should be doing :wink:
Riding in BZR4age's Levin I noticed that his oil temp wouldn't get above 80degrees on the street with just normal driving (has a thermostat). On the circuit no doubt it's a good idea, but if just comuting all you are going to do is keep the oil on the cold side.
TRD Clicky >>Here
1I1
Postby Quint » Wed Jan 26, 2011 1:35 pm
touge_ae101 wrote:especially when 4ages are susceptible to run bearings so easily, you don't want your oil thinning out much.
Part of the blame for me running my bearings at mainfield. If you're going to put it on a track, put an oil cooler on it.
Quint
Postby deaf_rattle » Wed Jan 26, 2011 4:05 pm
yep, make sure you run a thermostat, because you dont want it taking forever getting to temperature either.
cheap thermostats can be found at www.summitracing.com
Postby touge_ae101 » Wed Jan 26, 2011 4:12 pm
1I1 wrote:On the street it would never get that hot as it requires you to be reving the car to redline over and over again = not really something you should be doing :wink:
depends how you drive it on the street. in can think of a few occasions where redline has been seen for extended periods of time where i think my oil cooler would have definately helped! :wink:
touge_ae101
Postby Bling » Wed Jan 26, 2011 4:41 pm
I'm sure if it was needed, it would have come with it standard. If you're just looking to throw some coin around though, then i'm sure it will soak some up for ya. Save it for ya 3s :wink:
Postby 1I1 » Wed Jan 26, 2011 4:46 pm
Heh, and they would have designed the oil system to be more than 3.3 litres with filter!
TRD Clicky >>Here
1I1
Postby rx7guy » Wed Jan 26, 2011 6:43 pm
Some AW11's come with oil coolers from factory, cant be such a bad idea if your oil does get a bit hot.
The torque band is wide and the road is narrow
rx7guy
Postby jondee86 » Wed Jan 26, 2011 6:52 pm
Under 100 deg is a good rule of thumb for everyday driving. Up to
120 deg when racing is kind of acceptable, but anything over 120 deg
should be considered too hot. The temperature at the bearins will be
quite a bit higher than the circulating oil temp, so at 140 deg your
bearings are not going to stay happy for long !! My $ 0.02 worth :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby BZR4AGE » Wed Jan 26, 2011 6:53 pm
The max i've ever seen with my oil cooler setup was 120C running around pukekohe.
BZR4AGE
Postby 1I1 » Wed Jan 26, 2011 9:38 pm
And there's a fair bit of reving done on Puke!
TRD Clicky >>Here
1I1
Postby Boost_4_Life » Thu Jan 27, 2011 8:18 am
i dont run one on the rally car, but been seriously thinking about it lately.. i dont have an oil temp gauge. If i did id probably be worrying more :lol: Wheres the best place to get all the bits i would need, filter adaptors etc?
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Mr. Mainstream » Thu Jan 27, 2011 8:50 am
wouldn't oil grades make a noticeable difference?
though i cant see how modding up a aw11 cooler would be too hard
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
