Malcolm wrote:I didn't know they had maths on waiheke
Quirky wrote:My 4ag turbo with no oil cooler doesn't get above 98 degrees c at the drag strip.
And thats 2 hours, about 10 passes.
When and if, it reaches 100 degrees, ill probably start worrying.
touge_ae101 wrote:especially when 4ages are susceptible to run bearings so easily, you don't want your oil thinning out much.
1I1 wrote:On the street it would never get that hot as it requires you to be reving the car to redline over and over again = not really something you should be doing
Riding in BZR4age's Levin I noticed that his oil temp wouldn't get above 80degrees on the street with just normal driving (has a thermostat). On the circuit no doubt it's a good idea, but if just comuting all you are going to do is keep the oil on the cold side.
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Users browsing this forum: No registered users and 32 guests
